1 - 7 of 7 Posts
Jman414
Discussion starter · #1 ·
I currently have a headlight out on my driver side of my 2006 to touareg v8. My brights and turn signal work but not my daytime running lights or regular light. Already replace the buld. Still not working....what could it be?
Assuming you have bi-Xenon
-Fuse
-Wiring harness
-Bad connection at connector
There are a number of threads that address light out issues.
I checked them all. Do you think it could be the balast?
To test that take the assembly out and plug into the other side. You can lift the connector up and pull out enough to test the other side's light.
Yes.
Remove the driver side assembly.
Pull out the passenger light and put it to the side.
Lift the connector and pull it forward a few inches.
You should then be able to plug in the drivers side assembly and turn it on to see if it works.
1 - 7 of 7 Posts
