1 - 3 of 3 Posts
Problem retrofitting Bluetooth Module
Hi
I just retrofit a Bluetooth module (9W7) on my touareg . But I can't access the module. I enable the can gateway 77 , the module work I can stream music , make and receive call , I got access to my phone book thru my radio ,
But I can't see any information on the MFI .
Not sure why I can't access the module .
Don't just put "Need help" as the title of a thread!
Put the problem in the title!!
That way people can see if it is something they may be able to help with and, later, if you find a fix, others with the same problem might find your thread to help them too.
Hi
I believe that your cause will be because you are using the 9W7 unit instead of the 9W3. I am advised by a member on here that I put a lot of faith in and who has done heaps of mods to his that the 9W7 unit uses a different communication protocol and will work thru the RNS510 but not talk to the rest of the car.
I have the 9W3 unit and all the info is in my MFD.
And as Nooby said use a more descriptive heading it will help others.
regards
Drag
1 - 3 of 3 Posts
