After months of waiting the new ebox/module for the towbar was available for the M21 Touareg.
I don't know what exactly has changed but this module is different to the previous years.
Few pictures of the installation, highly recommend VW towbar installation, all up there were 9 modules recoded and the 10th ie 69 was installed, so you can imagine how much the electronics are interconnected.
Following modules have to be recoded for the towbar:
09, 13, 17, 3C, 46, 6D, 74, A5, 5F and finally 69.
The kickopen function continues to work well, just kick anywhere on either side of the towbar
Would be interesting to see, compare what aftermarket installers do...
The additional indicator on VC is cool, alerting that the blinkers on the trailer are working/flashing, with the 1 on it.
Towed the jetski around and tested it works well. The start stop gets remapped- doesn't switch off as often, going downhill it drops into lower gear compared to not having the trailer, rear traffic alert etc are disabled- it alerts/reminds you on the vc as you start and then goes away, note remains in the vehicle status messages if you want to scroll...
All up a very neat install with everything working the way it should be.
When reversing to hitch the trailer the guided line to the receiver of the trailer which comes up on the screen is very accurate, line it up and raise the suspension to latch, too easy!
Few pictures
Few pictures
