1 - 12 of 12 Posts
2009 T2 3.6L VR6 FSI
Hi everyone. So I've finally joined the ranks of VCDS owners and just did my first autoscan. And it's a bit confusing. Something are obvious but others seem to need some interpretation. So if I may pick your brains a bit to elaborate a bit on what VCDS is trying to tell me.
Thanks and appreciate your comments.
Chassis Type: 7L (6N0)
Scan: 01 02 03 05 08 09 15 16 17 19 22 37 46 55 56 68 6D 76
VIN: WVGAL27L89D006525 Mileage: 228830km-142188miles
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
22-AWD -- Status: Malfunction 0010
37-Navigation -- Status: Not registered 0011
42-Door Elect, Driver -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: Malfunction 0010
68-Wiper Electr. -- Status: OK 0000
76-Park Assist -- Status: Cannot be reached 1100
Address 01: Engine (BHK) Labels: 03H-906-032-BLV.clb
Part No SW: 03H 906 032 CR HW: 03H 906 032 S
Component: T-GP 7GH G 1671
Revision: 5FH04--- Serial number: VWX3Z0H1769647
Coding: 0001175
Shop #: WSC 31414 790 00001
VCID: 74B1D1E2F2AE054BDB7-5160
VINID: 9E65D17021DC209500006142142CE8050E
4 Faults Found:
008598 - Oxygen (Lambda) Sensor B1 S1
P2196 - 002 - Signal too High (Rich)
Freeze Frame:
Fault Status: 01100010
Fault Priority: 0
Fault Frequency: 191
Reset counter: 255
Mileage: 216242 km
Time Indication: 0
Freeze Frame:
RPM: 2082 /min
Load: 71.3 %
Speed: 95.0 km/h
Temperature: 87.0°C
Temperature: 39.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 14.224 V
008342 - Post-Catalyst Oxygen (Lambda) Sensor Correction; Bank 1
P2096 - 002 - Too Lean
Freeze Frame:
Fault Priority: 0
Fault Frequency: 77
Reset counter: 255
Mileage: 216277 km
Time Indication: 0
Freeze Frame:
RPM: 1962 /min
Load: 41.2 %
Speed: 22.0 km/h
Temperature: 68.0°C
Temperature: 20.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 15.113 V
008816 - Oxygen (Lambda) Sensor Signal B1 S2
P2270 - 001 - too Lean - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 36
Reset counter: 255
Mileage: 223378 km
Time Indication: 0
Freeze Frame:
RPM: 1379 /min
Load: 30.6 %
Speed: 37.0 km/h
Temperature: 87.0°C
Temperature: 46.0°C
Absolute Pres.: 990.0 mbar
Voltage: 14.224 V
004372 - Oxygen (Lambda) Sensor; B1 S2
P1114 - 008 - Internal Resistance too High - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 31
Reset counter: 255
Mileage: 224495 km
Time Indication: 0
Freeze Frame:
RPM: 1803 /min
Load: 85.5 %
Speed: 65.0 km/h
Temperature: 87.0°C
Temperature: 46.0°C
Voltage: 14.224 V
Readiness: 0000 0001
Address 02: Auto Trans Labels: 09D-927-750.clb
Part No SW: 09D 927 750 HJ HW: 09D 927 750 HJ
Component: AL 750 6A 1406
Revision: 00H75000 Serial number:
Coding: 0004200
VCID: 7DA7F4C6C1E44403A49-5160
No fault code found.
Address 03: ABS Brakes Labels: 7L0-907-379-MK25E1.clb
Part No SW: 7L0 907 379 P HW: 7L0 614 517 C
Component: ESP ALLRAD MK25E1 0304
Revision: 00H53001
Coding: 0010498
VCID: 46D55B2AD4E2C7DBB53-8012
1 Fault Found:
03197 - StopPing Distance Reduction 2 in ADR Control Module (J428)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 255
Reset counter: 103
Mileage: 207044 km
Time Indication: 0
Date: 2020.11.06
Time: 00:10:21
Freeze Frame:
Count: 128
Count: 13057
Count: 8244
Count: 1
Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl
Part No SW: 3D0 909 139 D HW: 3D0 909 139 D
Component: Kessy 6850
Revision: 00H22070 Serial number: VWX3Z0H1769647
Coding: 0000232
VCID: 2A0D0F9A60BA03BBB1B-807E
Component: ELV XXXX
Part No: 7L6 907 040 AH
Component: CLIMAtronic R/L 4334
Coding: 0021020
VCID: 76B5EBEAE482175BE53-8022
1 Fault Found:
00353 - Function Return Message from Fresh Air Blower Regulator
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Voltage: 14.40 V
Voltage: 11.07 V
Voltage: 13.34 V
Voltage: 14.00 V
Address 09: Cent. Elect. Labels:. 7Lx-937-049-V2.clb
Part No SW: 7L6 937 049 AF HW: 7L6 937 049 AF
Component: J519 2002
Revision: -0004--- Serial number: --------------
Coding: 600004003B061C000000000000000000
VCID: 00598D32B64629EBCFF-8054
1 Fault Found:
00978 - Lamp for Low Beam; Left (M29)
007 - Short to Ground - Intermittent
Address 15: Airbags Labels: 7L0-959-655.lbl
Part No SW: 7L0 959 655 HW: 7L0 959 655
Component: J234__36 VW8T 0250
Revision: 92012025 Serial number: 0039P005CD5T
Coding: 0013110
VCID: 7AADFFDAD09A733B81B-802E
1 Fault Found:
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 207050 km
Time Indication: 0
Date: 2020.11.06
Time: 21:58:21
Part No: 7L6 953 549 F
Component: J527 3601
Coding: 0010011
VCID: 42DD473AF8CAFBFB99B-8016
Address 17: Instruments Labels: 7L6-920-xxx-7L6.lbl
Part No SW: 7L6 920 875 P HW: 7L6 920 875 P
Component: J285 KOMBI-INST. 8828
Revision: KHH05V35
Coding: 0007601
Shop #: WSC 16073 002 1048576
VCID: 48C95512DEB6D1AB47F-801C
Address 19: CAN Gateway Labels:. 6N0-909-901-7L.clb
Part No SW: 6N0 909 901 HW: 7L6 920 875 P
Component: J533 GW-K-CAN TP20 8828
Coding: 77E2E79940046002
VCID: 70B9DDF286A6396B3FF-8024
2 Faults Found:
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 106
Mileage: 207052 km
Time Indication: 0
Date: 2020.11.09
Time: 00:00:00
01327 - Control Module for Parking Aid (J446)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 103
Mileage: 207044 km
Time Indication: 0
Date: 2020.11.06
Time: 00:10:55
Address 22: AWD Labels: None
Part No: 0AD 927 755 BG
Component: TRANSFERCASE 0126
Shop #: WSC 00000 000 00000
VCID: 015F8836BD1C20E3C01-5160
2 Faults Found:
02039 - Position Sensor in Transfer Case (G398)
008 - Implausible Signal - Intermittent
Address 37: Navigation
Cannot be reached
Part No: 7L6 959 933 A
Component: 23 HSG 0601
Coding: 0000085
Shop #: WSC 16077 002 1048576
VCID: 40D94D32F696E9EB8FF-4B3C
Subsystem 1 - Part No: 7L0 959 701 M
Component: Tuersteuergeraet FS 6304
Subsystem 2 - Part No: 7L0 959 702 M
Component: Tuersteuergeraet BF 6304
Subsystem 3 - Part No: 7L6 959 703
Component: Tuersteuergeraet HL 0202
Subsystem 4 - Part No: 7L6 959 704
Component: Tuersteuergeraet HR 0202
2 Faults Found:
00932 - Electric Window Motor; Drivers Side (V147)
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
00930 - Locking Module for Central Locking; Rear Left (F222)
Address 55: Headlight Range Labels: 7L6-907-357-A.lbl
Part No SW: 7L6 907 357 A HW: 7L6 907 357 A
Component: AFS-Steuergeraet 0001
Revision: H02 Serial number:
Coding: 1286275
VCID: 392F20D6951CB823C81-806C
Subsystem 1 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul l S002
Coding: 00000019
Subsystem 2 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul r S002
Coding: 00000019
Address 56: Radio
Cannot be reached
Address 68: Wiper Electr. Labels: 7L0-955-119-V2.clb
Part No: 7L6 955 119 B
Component: J400__ Front Wiper 5301
Coding: 0001397
VCID: 392F20D6955CB823C81-806C
Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 050608 054 0402
Coding: 00208941
Shop #: WSC 31414
Address 6D: Trunk Elect. Labels: 7L6-959-107.clb
Part No SW: 7L6 959 107 B HW: 7L6 959 107 B
Component: J605 HECKKLAPPE 1310
Revision: --H05--- Serial number: --------035626
Coding: 0122110
VCID: 3A2D3FDA901AB33BC1B-806E
Address 76: Park Assist
Cannot be reached
End----------(Elapsed Time: 02:27, VBatt start/end: 12.3V/12.3V)-----------
2011 VR6 FSI LUX
Coding: 0001175
4 Faults Found:
Freeze Frame:
Fault Priority: 0
Reset counter: 255
Mileage: 216242 km
Time Indication: 0
Freeze Frame:
RPM: 2082 /min
Load: 71.3 %
Speed: 95.0 km/h
Temperature: 87.0°C
Temperature: 39.0°C
Voltage: 14.224 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 77
Reset counter: 255
Mileage: 216277 km
Time Indication: 0
Freeze Frame:
RPM: 1962 /min
Load: 41.2 %
Speed: 22.0 km/h
Temperature: 68.0°C
Temperature: 20.0°C
Voltage: 15.113 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 36
Reset counter: 255
Mileage: 223378 km
Time Indication: 0
Freeze Frame:
RPM: 1379 /min
Load: 30.6 %
Speed: 37.0 km/h
Temperature: 87.0°C
Temperature: 46.0°C
Voltage: 14.224 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 31
Reset counter: 255
Mileage: 224495 km
Time Indication: 0
Freeze Frame:
RPM: 1803 /min
Load: 85.5 %
Speed: 65.0 km/h
Temperature: 87.0°C
Temperature: 46.0°C
Voltage: 14.224 V
Coding: 0004200
Revision: 00H53001
Coding: 0010498
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Reset counter: 103
Mileage: 207044 km
Time Indication: 0
Date: 2020.11.06
Time: 00:10:21
Freeze Frame:
Count: 128
Count: 13057
Count: 8244
Count: 1
Coding: 0000232
Component: ELV XXXX
Coding: 0021020
1 Fault Found:
Freeze Frame:
Voltage: 14.40 V
Voltage: 11.07 V
Voltage: 13.34 V
Voltage: 14.00 V
1 Fault Found:
Coding: 0013110
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 207050 km
Time Indication: 0
Date: 2020.11.06
Time: 21:58:21
Coding: 0010011
Revision: KHH05V35
Coding: 0007601
2 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 106
Mileage: 207052 km
Time Indication: 0
Date: 2020.11.09
Time: 00:00:00
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 103
Mileage: 207044 km
Time Indication: 0
Date: 2020.11.06
Time: 00:10:55
2 Faults Found:
Cannot be reached
Coding: 0000085
2 Faults Found:
Coding: 1286275
Coding: 00000019
Coding: 00000019
Address 56: Radio
Cannot be reached
Coding: 0001397
Coding: 00208941
Shop #: WSC 31414
Coding: 0122110
Cannot be reached
If you have a genuine VCDS you should be joining/posting this on those forums. You will have to wait to be verified before you can post.
Just remember to follow the guide for posting auto-scans when you do.
How to post >>>
With that said check the condition of your battery. Lots of codes like that usually , but not always, occur when the battery is going dead.
Save your log (looks like you already did ), then clear all the codes DTC's..
See if any come back.
Like was what said above, could be a bad battery (YES a weak low voltage battery can cause a multitude of false trigger faults).
I just cleared a nuisance code that sent my vehicle into limp mode. I changed the fuel filter, a ALMOST topped off the filter housing with clean diesel additive, but there was a small 1/4 inch air gap, MEH, I think, and bolt the top back on. I start the engine, no problem and roll down a long hill, take a right turn and get on the accelerator and BOOP, get a squiggly glow plug fault lamp on the instrument cluster and went into limp mode!!! 30mph.....
I pulled into a business parking lot. Shut down the engine, and waited about a minute. Turned the engine on and no light, no problem, It was likely the air gap purging and later on I did a VCDS scan. The VCDS log showed P0087 code, low fuel rail pressure. Yep, must have been some air purging and caused limp mode. Cleared the code. It runs fine no worries for me.
Your Touareg may remember codes for a long time if they have never been cleared. If a mechanic or owner is fixing things and never cleared any fault codes, it will remember them.
Thanks. I'll clear the DTC's and see if any come back.
Discussion Starter · #6 ·
Which one of these do you need help with?
I'm mainly concerned wit the engine fault codes coming from the oxygen sensors. I don't know if these were the result of the recent vacuum leak that occurred. I've since replaced the valve cover gaskets and all is well again. So I will go ahead now and clear all the codes and see what comes back.
'14 TDI Execline
You need to dechiper the FF data.
Read and browse the online manual to get basic understanding.
Code:
Freeze Frame:
Fault Priority: 0
Reset counter: 255
Mileage: 216242 km
Time Indication: 0
First number is VAG specific code
Second is generic code
3 digit number designates error type... Short to positive, short to negative, out of range, etc
Fault status tells you about things like if it's an active fault, if it's been confirmed, tested since last clear, if it's causing the CEL, if it's pending, etc
Priority tells you how serious the issue is
Freq is self explanatory - it's happened 191 times since the first error
Reset counter is basically how many ignition cycles it needs to see without the error to clear itself.
Milage and time stamp is the last recorded event... Don't get all sideways about the date as some controllers have no idea what date it is and will report incorrect dates.
Let me know if that's the kinda help you're after, or if you want to go into more detail, etc.
Discussion Starter · #8 ·
Code:
Freeze Frame:
Fault Priority: 0
Reset counter: 255
Mileage: 216242 km
Time Indication: 0
Thanks. This has shed some light on the information above. I would like to know what it's trying to tell me though. Do I have bad O2 sensors? Is that what's triggering the codes?
'14 TDI Execline
Ok, so now you start digging into it. Depending on engine and sensor, it will mean various things. In this case, the respective bank is running rich. So one of those cylinders is getting too much fuel, or the sensor is just worn out and acting up and is reading incorrectly. Start troubleshooting. You can read live values off the sensor, or log the output to see if it always happens at a similar rpm/load condition, etc.
Look at your overall system. Have you noticed a drop in MPGs recently? Do you smell fuel at your exhaust? What does reading the spark plugs tell you? If none of those show any signs of running rich, then you could very well have a sensor that needs to be replaced.
If you look up the error in a service manual, you can most likely find the range that it's supposed to read in, and if you compare that to your live readings or log, you can see when it acts up.
'14 TDI Execline
Given that both your pre and post cat sensors have errors, their fault frequency, and your age\milage, I'd say you'd probably be safe replacing both of them. If you'd rather only start with replacing one of them, I'd suggest you replace the pre cat one.
I believe I also recall you recently having coil issues, which would've contributed to these rich\lean conditions.
Discussion Starter · #11 ·
I would imagine that the codes would have cleared after replacing the defective coils and fixing the vacuum leak it developed a couple weeks ago. But they still come back, so, I guess it's time to break the piggybank and get new sensors.
'14 TDI Execline
You had crappy coils and vacuum system leaks. What did your plugs look like? Pull the plugs and see if they are fowled up, wet, worn out, melted, etc.
You have a good diagnostic tool now. Use it to read both sensors that are causing codes. Log their output.
Have you cleared the codes and gone for a drive to see if the errors would come back right away?
Look at the milage stamps on those codes vs your current milage.... they happened long ago!
1 - 12 of 12 Posts
