Hey guys, I just got my exhaust done and thought I'd share the route I went.
I had the unfortunate experience with Troy Kirk and did end up getting my money back for the "DPF delete". Well he decided to send me one anyways, for free. Comes in and it's just a down pipe. So I kicked around even using it for a while. Well I did and I'm glad I did.
I heat wrapped it and sealed it with silicone heat wrap paint from DEI.
I took it down to a local exhaust shop who made the mid section for me. Full 3" stainless mandrel to the stock rear section (2.5"). So I've deleted the Cat as well as the SCR and DPF.
Here is a video of the sounds in and out of the car.
Inside:
And outside
https://www.facebook.com/groups/VWDiesel/permalink/964573293619720/
I have a couple questions.
I normally run the Liqui Moly 4200 but without the DPF what can I run in the Liqui Moly family.
Also I've gotten an overboost code a few times. The tune was updated to a DPF delete, but it's possible that the cat was not deleted in the tune as well. I'm waiting on a response. If the tune is good, which I'm guessing it is due to how the logs look, then I guess I'm looking at a turbo issue.
This is my second boost log, I logged it cruising around 2500rpm because that's where the codes were being thrown, sure enough I noticed a difference so I logged it. That's the flat section.
Haven't had this issue before the exhaust, so I'm hoping it's just a tune and lack of back pressure issue, but it seems random so it's probably not.
Inside:
And outside
