Here is the setup I just completed on my V8, I'm sure the same would fit the V6 -1 air box.
After about the fifth time cleaning my K&N they started to look a bit mangled. Like my neighbors cat. I decided it was time to change them completely instead of cleaning. I really like the look of the cone air filters but I know there is no setup for the Treg. Or at least what I would want to pay.
I cleaned my MAF sensors, ever since the piece connecting to the air box has been fragile. It looks like a trumpets end. It easily breaks out of the air box with enough force. Hey, clean that MAF sensor while you're in there too.
I went to Advance Auto and picked these filters, by measurement, they were they best fit. Please take my many fit and fails to your advantage. Also, if you find these online, it'll tell you if your local Advance Auto has these in stock and you can add them to cart and buy them online with a 30% off coupon like I did and pick them up in store. So cheap!
I left the main air box in, you can take them out (10mm bolt) but they have a air flow director to direct air from the front of the car to the air box. The passenger side has some tubes for the secondary air injection and other bits. I just directed these towards the air flow and glued them in place, or you can clamp and drill them in place. Better yet; do it the right way and drill them directly into the cone. I didn't have time for this and well that's a process. In the end, I did notice a noticeable power increase and mpg gain. I don't think these are too big or too small either. I've included pictures of the parts and some of the process. It's a very tight fit, in the end I added some red led strips (comes with 2, $18.99) to the engine bay and painted the intake black (high temp black engine paint). Welcome to any questions and comments. Enjoy, hope this helps anyone.
2x Spectre Air Filter from Advance Auto - $26.99. 8132 is the item no.
TRT30 is the 30% off code for $50+. Which will add up to be two of these. There is an option to buy online and pick up in store, if they have it in stock. (To be able to use the coupon).
