21 - 34 of 34 Posts
Discussion starter · #22 ·
I don't consider the state responsible (because of an irresponsible dealer). If you make a machine like this, you have to make it compatible with the vehicle so that the owner doesn't get traumatized while driving! It's very traumatic to drive a car like this, today I broke down 4 times in a distance of 70 km. There is no solution for this, so if you are selling an item of 500 fr or Eu, it should work well and correctly!!! Who among you all wants to buy something this expensive and cause problems??
Cheap crap off AliExpress is not made for quality in general, it is made to look pretty and to sell to people once, they aren't building a brand based on quality and reliability. You buy off AliExpress if you have low expectations, or know exactly what you are after. Remove the crappy thing you have installed, put the vehicle back to standard. Order a head unit that is well received by others, and that isn't that silly Tesla style.
There’s a reason why AliExpress and Amazon sell multiple copies of same thing. They’re all made in the same factory, they just mash the keyboard differently. Aggtfeeyu, HDNRRYHALL, HAPPYENDING, QYERVBYYJ are all the same company producing the same crap.
Discussion starter · #25 ·
therefore, there is no progress in solving this problem, the only way out of this problem is to return it, meaning some normal multimedia that does not interfere with the air conditioning system, because as soon as it interferes with the air conditioning system, the car recognizes it as an error, so here you are now, now I have attached diagnostics with standard air conditioning so you can go into the climate control system itself and see what its problems are when it is connected There is no way you can go into the climate control and examine all its errors so a simple solution to remove this
Looks like you have several issues to attend to. First would be removing the cheap chinese unit and get an android auto head unit that has nothing to do with your climate controls.
Discussion starter · #28 ·
I already bought on ebay from a seller the original climate control for the Touareg for 170 euros with DHL delivery and the Android multimedia which has no contact points with the climate control. All this I am doing is proof that you should not buy MULTIMEDIA of this type because they cause problems.
Discussion starter · #29 ·
The manufacturer from China is hiding these problems well. And another important thing is that when you have this multimedia, you cannot read the parameters of the climate controller. Via VCDS or WOW or DELPHI, none of the diagnostics have access to the climate controller. Access is returned with the original climate control unit.
Discussion starter · #30 ·
I think all the people who installed this multimedia in their TOUAREG had the same problems because the ECU doesn't have the AC Controller signal because it just doesn't see it.
Discussion starter · #32 ·
Hello so here I will thank all of you from the bottom of my heart for the support you gave me, so I solved the problem by myself, that is, I put another multimedia normally, I returned its factory air conditioner, and the work shop system fout disappeared, so all of you who have this problem do the same like me in here in the text itself I will put my video otherwise I am a youtuber so you can watch it as I did a short but concise video.
Great, that looks really nice! I am jealous of the sharpness and resolution of your backup camera through that system. Did you replace the camera itself, or are you still interfacing the factory camera?
Discussion starter · #34 ·
VW TOUAREG FROM 2003 it does not have cameras or parking sensors, I installed Multimedia Tesla Style for the first time and it turned out to be a mistake, I proved it. Otherwise, now this looks very nice, at least for my taste, otherwise this is what I have so far, who knows how many touaregs I have driven so far 5.0 3.6 3.2 and 2.5 what I would like the old model 6.0 V12
21 - 34 of 34 Posts
