Good thinking, will see if it will attach, no will paste instead.
Saturday,07,May,2016,11:37:04:02999
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
Ross-Tech: Home
VIN: WVGZZZ7LZ8D043538 License Plate: DU09FYH
Chassis Type: 7L (6N0)
Scan: 01 02 03 05 08 09 15 16 17 18 19 22 37 46 56 68 69 76
VIN: WVGZZZ7LZ8D043538 Mileage: 132810km-82524miles
01-Engine -- Status: OK 0000
05-Acc/Start Auth. -- Status: Sporadic communication error 1000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
18-Aux. Heat -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
22-AWD -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
68-Wiper Electr. -- Status: OK 0000
69-Trailer -- Status: OK 0000
76-Park Assist -- Status: OK 0000
Address 01: Engine Labels: 059-907-401-ASB.clb
Part No SW: 7L0 907 401 F HW: 7L0 907 401 D
Component: 3.0L V6TDI G000AG 0040
Revision: --H05--- Serial number: VWX3Z0G1681844
Coding: 0011779
Shop #: WSC 31414 790 00001
VCID: 2E533446BA1CF24EDC-5140
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 09D-927-750.lbl
Part No SW: 09D 927 750 FA HW: 09D 927 750 FA
Component: AL 750 6A 0992
Revision: 00H61000 Serial number:
Coding: 0004456
VCID: 72EBE0366EA496AE78-5140
Address 03: ABS Brakes Labels: 7L0-907-379-MK25E1.clb
Part No SW: 7L0 907 379 L HW: 7L0 907 379 L
Component: ESP ALLRAD MK25E1 0303
Revision: 00H53001
Coding: 0004354
VCID: 428B70F61984662E28-8016
Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl
Part No SW: 3D0 909 139 B HW: 5WK 485 04
Component: Kessy 6840
Revision: 68406620 Serial number: VWX3Z0G1681844
Coding: 0000232
VCID: 285FC25E9FF8AC7E16-807C
Component: ELV XXXX
Part No: 7L6 907 040 AF
Component: CLIMAtronic R/L 4331
Coding: 0000530
VCID: 74E7E62E13B0989E6A-8020
Address 09: Cent. Elect. Labels: 7Lx-937-049-V2.clb
Part No SW: 7L6 937 049 AF HW: 7L6 937 049 AF
Component: J519 2000
Revision: -0004--- Serial number: --------------
Coding: 600001002B001C000000000000000000
VCID: 000FBAFE5708B43E7E-8054
1 Fault Found:
00455 - Control Module for Access and Start Control; Comfort CAN (J518)
Address 15: Airbags Labels: 7L0-959-655.lbl
Part No SW: 7L0 959 655 HW: 7L0 959 655
Component: J234 37 VW8T 0250
Revision: 92011025 Serial number: 0039P003A31B
Coding: 0013111
VCID: 7AFBC81631D4EEEE30-802E
Part No: 7L6 953 549 F
Component: J527 3601
Coding: 0010011
1 Fault Found:
Address 17: Instruments Labels: 7L6-920-xxx-7L6.lbl
Part No SW: 7L6 920 985 Q HW: 7L6 920 985 Q
Component: J285 KOMBI-INST. 7520
Revision: KHH06V02
Coding: 0007401
VCID: 4B955DD22ACEA766DB-801E
2 Faults Found:
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 199
Mileage: 132816 km
Time Indication: 0
Date: 2016.05.06
Time: 00:00:04
00447 - Function Limitation due to Over-Voltage
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 6
Fault Frequency: 3
Reset counter: 178
Mileage: 131086 km
Time Indication: 0
Date: 2016.03.02
Time: 09:47:11
Address 18: Aux. Heat Labels: 7L6-819-008.lbl
Part No: 7L6 815 071 G
Component: Standheizung E1MAC 0425
Coding: 0000000
VCID: 36631C26414CCA8E94-8062
Address 19: CAN Gateway Labels: 6N0-909-901-7L.clb
Part No SW: 6N0 909 901 HW: 7L6 920 985 Q
Component: J533 GW-K-CAN TP20 7520
Coding: 57E2E78B48056003
VCID: 70EFEA3E63A8A4BE8E-8024
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 199
Mileage: 132816 km
Time Indication: 0
Date: 2016.05.06
Time: 00:00:04
Address 22: AWD Labels: None
Part No: 0AD 927 755 BG
Component: TRANSFERCASE 0126
Shop #: WSC 00000 000 00000
VCID: 0109BFFA5B02BD3671-5140
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 7L6 035 680 B HW: 7L6 035 680 A
Component: RNS-MID H04 1102
Revision: AB001001 Serial number: VWZ6Z7G9284051
Coding: 020004000400002200
VCID: 31692F3A6822EDB6C1-8064
1 Fault Found:
00857 - CD Changer Unit (R41)
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 5
Fault Frequency: 1
Reset counter: 192
Mileage: 132616 km
Time Indication: 0
Date: 2016.04.26
Time: 22:52:54
Part No: 7L6 959 933
Component: 14 HSG 7124
Coding: 0000065
VCID: 7F0D39022DF6CBC607-4B00
Subsystem 1 - Part No: 7L0 959 701 R
Component: Tuersteuergeraet FS 6302
Subsystem 2 - Part No: 7L0 959 702 R
Component: Tuersteuergeraet BF 6302
Subsystem 3 - Part No: 7L6 959 703
Component: Tuersteuergeraet HL 0202
Subsystem 4 - Part No: 7L6 959 704
Component: Tuersteuergeraet HR 0202
Subsystem 5 - Part No: 7L0 907 719 A
Component: Neigungssensor 0020
Subsystem 6 - Part No: 7L6 951 171 B
Component: Innenraumsensor 0020
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 192
Mileage: 132616 km
Time Indication: 0
Date: 2016.04.26
Time: 22:52:54
Address 68: Wiper Electr. Labels: 7L0-955-119-V2.clb
Part No: 7L6 955 119 C
Component: J400__ Front Wiper 5301
Coding: 0001397
VCID: 3A7B081675542EEE70-806E
Subsystem 2 - Part No: 1K0 955 559 AF Labels: 1K0-955-559-AF.CLB
Component: RLS 131107 046 0204
Coding: 00208933
Shop #: WSC 31414
Address 69: Trailer Labels: 7L0-907-383-1D2.lbl
Part No SW: 7L0 907 383 L HW: 7L0 907 383 L
Component: J345 Anhaenger 0080
Revision: 4A014001 Serial number: 00000107896841
Coding: 0000001
VCID: 3D71030A607A19D655-8068
Address 76: Park Assist Labels: Redir Fail!
Part No: 7L0 919 283 F
Component: 0E Einparkhilfe 1107
VCID: 3979171A745225F679-806C
End-------------------------(Elapsed Time: 03:08)--------------------------
