1 - 10 of 10 Posts
Hi can anyone advise if this can be done on this yr ?, (on both mirrors)
You tube shows an example on american model, but the AUS set up is different
Is it just me, or is the manual a useless generic one size fits all
Set your mirror knob to 'R' and leave it there. It only works with the passenger mirror.
Sent from my iPad using Tapatalk
Hi tried setting the mirror angle i wanted with it in R, fine,...but when i put it back in D or P it doesnt come back to the normal driving position ?
IIRC, mirror does not return to its normal position until you are moving forward.
Wouldn't you set it to "L" in Australia for the passenger mirror?
Not sure about the T3, but on my T2, the manual covers setting the passenger mirror to lower when you put it in Reverse. This is done through the MFD.
Correct - L for Aust.
Dipping mirror was not standard on my T3, so no MFD setting. Instead, I coded it via vag-com.
1 - 10 of 10 Posts
