1 - 1 of 1 Posts
Hi,
I have just bought a Touareg out here in Saudi as a run around, the other day the LH HID light stoped working. After switching things around I have worked out the build has gone, however I also think something is wrong with the ballast unit as the high beam and flash don't work on the LH light, all good on the RH light. Plugged HR light into LH side just to check wiring and all is fine. However, I did have a spare ballast unit which gave the same fault. Whilst I was looking into this fault I discovered that both halogen main beam lights don't work on flash or high beam. Whilst doing previous fault I discovered both halogen bulbs work fine. I instantly thought it wasn't a relay but can't find anything that discusses such a relay, any idea what could be the fault? 2006 Touareg 3.2 V6.
1 - 1 of 1 Posts
