1 - 6 of 6 Posts
Anacairo
Discussion starter · #1 ·
Our Touareg has been sitting for a while and we knew it was a project when we bought it. Has 312xxxk and we haven’t driven it much since we bought it. It is throwing at least 15 codes and a lot of them are low voltage or “power limit reached”. Does anyone know what I can do to fix these things? Do they need to be fixed? You have to feather the gas to get it to start and sometimes is stalls if you don’t keep the rpm’s up for a couple of seconds. Here are some of the codes
  • P0122 - Throttle Position Sensor (G69) Signal Too Low Lower Limit Reach Intermittent.
  • P0222 - Angle Sensor 2 for Throttle (G188) : Signal Too Low Lower Limit Reached - Intermittent
  • P0113 - Intake Air Temperature Sensor - 042 Signal Too High Lower Limit
    Reached - Intermittent,
  • P1564 - Throttle Actuator (J338): Under-Voltage during Basic Setting
    If anyone knows possible causes for these or how it can be fixed, please let me know. Thanks!
Sounds like low battery voltage. Could be due to old battery or bad/failing alternator.
Reactions: Anacairo
What ratio of kerosene to bunker fuel are you using on your 1910 Touareg?
1 - 6 of 6 Posts
