Banned
R5 (2008)
Why would you want to do that, even if it would be possible? It's so easy to remove the whole headlight, and a 2009 version shouldn't have the dreaded "locking mechanism broken" issue either.
Because I took the bulb assembly out easily, replaced the bulb. Now I can’t turn it far enough clockwise to engage the two tabs,
Read the manual, easy to get assembly out with no tools at all.
Banned
R5 (2008)
That doesn't explain why you do not want to take the whole assembly out, so you can put the bulb back.
