Hello Club Touareg Community,
I am the second owner of a 2014 CNRB v6 TDI treg with about 64,000 miles. I have noticed a small ticking noise about 6 months before I uploaded a Malone Stage 1 Tune. (Note the entire car is stock besides that tune + the Cayenne Trans map). Now 6 months later the ticking has gotten more noticeable and concerning.
While doing research into the possible reasons for the ticking noise, I learned about my injector deviation, and I was sure that was the cause. My deviations were off great then +- 1 units rising to sometimes +-2 units or worse when accelerating.
So I bought the tools necessary to remove my diesel injectors. I took off the two injectors furtherest away from the from 3 & 6 (sourcing this photo https://www.audi-sport.net/xf/attachments/198915/). I bought OEM copper crush washers and new stretch bolts. I cleaned the two TDI injectors that I had removed and put them back. I inspected my injectors and the tips had mushroomed slightly, enough for the copper washer to have wiggle room. Which made reinstall a bit more annoying.
After doing all this I checked my injector deviations and they were much better! I now range from +-.5 units, rarely reaching +-1.0 units. But the ticking noise is still there!!!
My next steps may involve cleaning out my intake manifold, and installing an oil catch can before my EGR valve. This would be to prevent the carbon build up.
I don't know what may be causing this ticking noise and I would prefer to fix it before a bigger issue occurs.
Attached below are some OBD 11 logs, after doing my injectors I think I got a coolant temperature sensor issue but I am not 100% sure. The Sensor "A" Circuit fault has also been there since before the Malone Stage 1 Tune. And VW dealership replaced the sensor for me but the fault came back a week later.
Also attached is a video of the engine ticking noise.
Thank you in advance,
LZ
OBDeleven vehicle history log
Date: 2024-11-10 14:31:30
VIN: WVGEP9BP0ED005274
Car: Volkswagen
Year: 2014
Body type: UNKNOWN
Engine: CNRB kW ( hp) l
Mileage: 104024 km
Full scan
Control Units: 24
Fault count: 5
Control Units:
02 Transmission
System description: AL1000 AISIN
Software number: 0C8927750CF
Software version: 3376
Hardware number: 0C8927750CF
Hardware version: 002
Faults:
No trouble codes found
03 Brakes
System description: MK25A
Software number: 7P0907379P
Software version: 0446
Hardware number: 7P0907379A
Hardware version: H36
Faults:
05 Keyless System
System description: BCM2 2.0
Software number: 4H0907064DK
Software version: 0510
Hardware number: 4H0907064DK
Hardware version: H35
Faults:
15 Airbag
System description: VW10Airbag02B
Software number: 7P0959655D
Software version: 0026
Hardware number: 7P0959655D
Hardware version: H06
Faults:
16 Steering Column
System description: Lenks.Modul
Software number: 4H0953568F
Software version: 0005
Hardware number: 7P6953507L
Hardware version: H04
Faults:
17 Dashboard
System description: Kombi
Software number: 7P6920982L
Software version: 0419
Hardware number: 7P6920982L
Hardware version: H13
Faults:
19 Gateway
System description: GW-CAN-L-MOST
Software number: 7P6907530J
Software version: 6032
Hardware number: 7P6907530F
Faults:
36 Driver Seat
System description: MEM-FS
Software number: 4H0959760D
Software version: 0153
Hardware number: 4H0959760D
Hardware version: H08
Faults:
46 Comfort System
Faults:
42 Driver Door
System description: TSG FA
Software number: 4H0959793AA
Software version: 0305
Hardware number: 4H0959793P
Hardware version: H02
Faults:
53 Parking Brake
System description: EPB
Software number: 7P0907801F
Software version: 1201
Hardware number: 7P0907801F
Hardware version: H51
Faults:
55 Headlight Regulation
System description: AFS-ECU
Software number: 7P6907357
Software version: 0110
Hardware number: 7L6907357C
Faults:
52 Passenger Door
System description: TSG BF
Software number: 4H0959792Q
Hardware number: 4H0959792M
Faults:
5F Multimedia
System description: H-BN-NA
Software number: 7P6035664D
Software version: 0706
Hardware number: 7P6035664A
Hardware version: H40
Faults:
56 Radio
System description: Radio U SIRIU
Software number: 4G0035082G
Software version: 0133
Hardware number: 4G0035082
Hardware version: H60
Faults:
62 Rear Left Door
System description: TSG HL
Software number: 4H0959795M
Software version: 0303
Hardware number: 4H0959795J
Hardware version: H03
Faults:
65 Tire Pressure
System description: RDKBERU25
Software number: 7P6907273F
Software version: 0008
Hardware number: 7P6907273F
Hardware version: H09
Faults:
6C Rear View Camera
System description: SG Rueckfahrkamera
Software number: 7P6907441A
Software version: 0020
Hardware number: 4H0907441
Faults:
69 Trailer Control
System description: Anhaenger
Software number: 7P0907383F
Hardware number: 7P0907383B
Hardware version: H11
Faults:
6D Deck Lid Control
System description: HDSG-Modul
Software number: 7P6959107C
Software version: 0043
Hardware number: 7P6959107
Hardware version: H10
Faults:
72 Rear Right Door
System description: TSG HR
Faults:
09 Central Electrics
System description: BCM1 2.0
Software number: 4H0907063CD
Software version: 0130
Hardware number: 4H0907063D
Hardware version: H12
Faults:
01855 - Left front seat temperature sensor
Intermittent
01 Engine
System description: 3.0TDI FSA
Software number: 7P0907401K
Software version: 0013
Hardware number: 7P0907401K
Hardware version: X21
Faults:
P245300 - Particulate Filter Pressure Sensor "A" Circuit
Range/Performance
Intermittent
P125700 - Coolant circulation valve
Open circuit
static
P125A00 - Thermal management
Coolant circulation implausible
static
08 Air Conditioning
System description: Klima 2 Zonen
Software number: 7P6907040BR
Software version: 1306
Hardware number: 7P6907040BR
Hardware version: H21
Faults:
U111300 - Function limitation due to received malfunction value
Intermittent
LZ
