Lightbar installation - 2021 CR
223 Views 3 Replies 3 Participants Last post by  MidnightTouaregV8
I have been told that when installing a light bar in order to access the high beam circuit one headlight must be removed. Is there an easier quicker solution to find the high beam circuit?
1 - 4 of 4 Posts
Wiring Diagrams
I don’t have a wiring diagram and can’t find it online b
You can Tee into existing high beam wire. I am unfamiliar with removing newer T-reg headlights, but on 7L it is very easy. After you get your h/l out, use a test light to find a high-beam wire.
AFIK, there is no other way to Tee into headlight wiring.
I suggest using the ground as the trigger to turn on the light bar.
Cheers...
1 - 4 of 4 Posts
