1 - 2 of 2 Posts
'06 v10 model. My front right was lower than the front left, so I decided to run though the VCDS adaptation. I did it twice, but each time when I got to the 05 it showed an error and would not let me confirm the values.
I am not trying to lower it, I just want to have it set at factory settings, but equal left to right.
From what I can glean reading various posts, you are possibly not allowed to deviate more than 5 mm per session? Is that correct? If so that would explain the errors as I was quite a bit off the stored factory values (497, 502) with:
01 - 473
02 - 463
03 - 484
04 - 481
There is also a mention in a post about doing it the Phaeton way, but that link to Vortex is dead. Anyone happen to know what that is? Otherwise this will take quite a while at 5mm a time.
Discussion Starter #2
Frustrated, I decided to try again this afternoon. With the now measured values of 471, 471, 483, 478 - it accepted all values the first time and adjusted the suspension upwards. The back is still a hair off, but I want to drive it some more before I try and sort that out perfectly.
So ignore the +-5mm or +-3mm range, at least for an '06 with these labels that does not apply:
Address 34: Level Control Labels: 7Lx-907-553-34.clb
Control Module Part Number: 7L0 907 553 F
Component and/or Version: LUFTFDR.-CDC- 3C3P1 3081
Software Coding: 0015521
Work Shop Code: WSC 31414 000 00000
1 - 2 of 2 Posts
