1 - 3 of 3 Posts
hello Guys had new thermostat fitted and now i have to put the key into the ignition as the start stop button is telling me its not been found!! anyone know how to solve this annoying problem?
Itis always helpful do describe which model/year/TDI (or not) etc of your car. It is also helpful to know which country you are in and which part of the country if you are in the US. It is usually useful for you to have searched this forum for potential similar issues.
And it is a standard first response to ask if you did a VCDS scan (which you will often see if you search at all) and what were the results.
1) Did you? [the VCDS scan]
2) What showed up?
3) Did you check the key battery?
4) What caused the thermostat to be changed and did the shop that changed it have any ideas about THIS issue? Is it possible that they bumped a wire and unplugged it and it needs to be plugged back in?
5) Have you consulted a dealer? Did you get the car from a dealer? Is there an extended warranty?
6) Is the car old enough to be susceptible to some of the Kessy / mosfet issues previously talked about? [searches would tell you that]
1 - 3 of 3 Posts
