1 - 20 of 38 Posts
Black 2004 V10
Hi has any one had there kessy repaired at AUTORONICS in the UK, mine had common faults, no keyless entry, no keyless lock and battery drain. they are now telling me that they can not check it for these faults and i need a new circuit board aprox $200.00 + the repair. on there web site they specialise in kessy repairs that is why i sent it there, i am now getting very concerned as with out it the car is useless, thanks for any input Vaughan.
Fixed my own KESSY. 2 Mosfets and 4 resistors on the left rear door module. Problem solved. Sorry, I don’t know anything about Autoronics in UK.
A new PCB $200! Thats is still a lot cheaper than going to a dealer and getting a new module which by the way is obsolete and they want you to get 5 modules so they can talk to each other. They wanted $4,270!!! I fixed it for $14! :)
You know, doing things like that is the reason VW is not posting record profits! Think of the harm you are doing! ;)
/joke
Black 2004 V10
/joke
i know your joking but if they charged a reasonable amount maybe they could move some of the older stock to owners that cars have depreciated to the point where the higher prices are not worth it.
Black 2004 V10
Get a used kessy on ebay. A carprog programmer and do the job for less than 100€. Just get the same part number as what you have. Do a vcds scan or check the part number on the old kessy.
Thanks for the info, i will give them until monday then tell them to send it back and look at alternatives, possibly your suggestion as i have seen one with the same numbers on ebay.
A similar post :
And be careful about lhd vs rhd modules. Get the one that fits your car. I already made the mistake of buying a door module from germany and not checking the rhd/lhd drive spec stuff. I toolk it for granted i was getting a lhd module from germany and ended up with rhd module from the uk.
Black 2004 V10
Discussion Starter #11
Well Autronics have just told me they can't fix or test my kessy and are sending it back, my car has been immobilised (sorry for the pun) for 16 days and prob 5 to 6 more for it to come back, i have looked for a S/H replacement but can't find one with the same letter on the end of the part number. looking for a solution to fix this kessy. The battery voltage has been stable at 12.58V for the 16 days, if the kessy wos installed the battery would be flat in 3 to 4 days.thanks for any help. Vaughan
What is you kessy part number? You can probably get away with an updated version.
What makes you think that you don't need to just have the mosfets and resistors replaced?
Here is one L version from Europe:
Latest version is apparently 3D909137FX. Best way to find out is to go to a dealer and give them your vin and ask for a kessy module replacement quote. They will give you the updated version. Remember you still need reprogramming the new kessy.
You have sellers on ebay selling kessy modules with pin and ready to use. I don't have any experience with this but you can always contact the sellers, give them your touareg model and year and get the info you need.
Black 2004 V10
Discussion Starter #17
Autronics in the UK have tested the unit and told me that they were ok, i sent it to them when i came across there advert about kessy repairs, you send your module to them they repair it and send it back no programing required. Mine has what i thought common problems no keyless lock or entry and a battery drain.
Black 2004 V10
Discussion Starter #18
when i get the module back can i test the mosfets and resistors myself with a multimeter?
Black 2004 V10
Discussion Starter #19
I have just checked with my local dealer and the 3D0909137FX is the replacement kessy but they want $1900.00 ex Germany.
Black 2004 V10
Discussion Starter #20
Hey TRespect i gave my local VW dealer my vin and the replacement kessy is in fact the 3D0909137FX, i have purchased a second hand kessy with this number and a pin number from ebay. The dealer said he can program this to my car i am just concerned that it will match up with the rest of my car, the dealer is unsure but said that is the one he would fit if i just booked it in for a kessy problem. do you know if i will have any problems with the newer kessy, thanks Vaughan.
1 - 20 of 38 Posts
