Kessy Problem.
522 Views 9 Replies 4 Participants Last post by  Zoli.
2
Hi guys my kessy died so i need a used one. in my car is a 3d0 909 135 q.
The question is can i use little different one (3d0 909 135 N for exemple)
See less See more
1 - 10 of 10 Posts
Last letter is probably the revision. The frequency is the same on both so I don't see a reason why you can't use it. Unless it has component lock it 'should' work. I can't confirm this as I've never had to change one.
Kessy handles on the other hand.....
Wheres that Touareg kid at... @SaVAGeSoot bring his ass over
The question is can i use little different one (3d0 909 135 N for exemple) View attachment 258380 View attachment 258381
what year, what engine, where in the world is it. if its older generation modules then it could be an easy internal fix. Namely resistors, and MOSFETS. Are you good at soldering?
Hi its a 2005 v10tdi located in Hungary.
OK, understood.
The first Touaregs did have problems with KESSY modules resistors and MOSSFETS burning out on the PCB. It has been done before by a few guys here.
Do you have any small electric parasitic draw from your car battery over time? This is a common fault when these components burn out. The fix, if it is the problem, is desoldering these components and soldering new ones back on. A cheap fix!
If it is something else, then I have heard that changing to different rev on modules can give you headaches when trying to pair with the other 5 modules.
Its has a big draw if i close the car but when is not closed not problem. It also make a clicking noise.
6
Are you confident in opening the module and look at the PCB. From what you are saying, that seems to be the problem.
See less See more
i opend it but not seen any burned out component. but should i give it a try changing them ?
1 - 10 of 10 Posts
