Hi All.
I have a 2008 R50 V10. Thinking I have a kessy problem but I will give a brief outline of problem. Car will not crank for long enough to start 1 in 20 times. I use the key although car has factory push button. Turn the key to start and engine only cranks for a very short time. Not long enough to start. Hold the key in crank position and it will still only crank for a very short time. Normally a few tries with the key and in will crank for long enough to start. lately the central locking is strange. I use the fob key. Sometimes I lock the car and it immediately unlocks. looking at the locking problem further and the door handles only work sometimes to unlock. Black buttons work sometimes. If you press the rear door black buttons there is a clicking sound from under the dash. Sounds like a relay going crazy. Last 10 seconds or so then no more clicking. Car is not used frequently so I do have battery draining issues that didn't concern me until all of the above. Now I am thinking Kessy module.
I have located the clicking noise to be from the kessy module.
I have a Vagcom and scans are attached. I have scanned many times and I never get aerial issues. Usually get power supply issues to Kessy. Sometimes no errors but the door handles will still not work. Key works OK
I have read the DIY repairs to the kessy module but would prefer a professional to do the repair. Where in Australia or preferably Melbourne can I go for Kessy repair, change over or replacement unit. I do not even know a stealer that is up with these problems.
Pictures below of my Kessy. By the date I am thinking this is not the original unit. Anyone know this number.
Regards Eric
Regards Eric
