Thanks. Aux is connected. But the aux option is greyed out. However if I connect it to the lightning cable dongle in the arm rest then it works. Shouldn’t it work wirelesslyThis question has been answered many times. If you have installed the kit correctly make sure you have aux selected on the radio and an AMI-3.5mm AUX plugged into the AMI port if necessary. If you want to hear audio being produced by your phone while you are connected to CarPlay you have to have AUX available and selected on the factory radio.
Ben, I apologize but I must be misunderstanding something. Where are you connecting the two ends of the 3.5mm adapter? Guessing it’s a female adapter that goes in the arm rest and the male from the joyeauto plugs into that?If you have the AMI-lightning adaptor plugged in that means you don't have the AMI-3.5mm adaptor plugged in.
Plug in an AMI-3.5mm adaptor into that port and you will be able to hear audio from the module. If you don't have one, purchase one then plug it in.
It’s the 8”Is your radio the 8" screen or the smaller 6.5" screen?
I’ll check my connections again. Thank you for the help Ben.You'll need to find a way to get the 3.5mm aux out of the module into the AUX input of your radio. Then select AUX and it will play through your speakers. If you bought a kit and the right parts for your car from Joyeauto this will be easy. If you didn't it will be more difficult.
The kit for the 8" Touareg comes with a green T-harness plug for the 3.5mm aux extention from the module. I don't know why you are talking about the extention cable having two male ends.
so how is it working out. was it worth it?Well was able to get it all wired up and connected and seems to work as advertised. I was crunched for time so didnt get any pics but will get some once i start putting everything back together.
Not sure i am too keen on just letting the module sit loosely behind the display to rattle around....may have to use some dounle sided tape or velcro tape to stabilize it....but who knows if it would ever be an issue....tomorrow is route the microphone somewherr day....
So far it has its quirks, but I will be looking at it in detail this weekend. So far the issues I haveso how is it working out. was it worth it?
So I connected the male end to the module and everything is working well. I routed the cable underneath the cup holder and routed it behind the screen. So you will need to cut a little slot to route the cable back from the arm rest console. The only thing you will miss out on is if you have Sirius XM in your vehicle selected, then you will not hear the sound from the CarPlay. If you have any particular questions, feel free to ask.so how is it working out. was it worth it?
how do you wire it into the #15 slot?Thank you! Hooking up the red wire fixed the issue for me. it works as advertised now. I did leave the blue wire connected as it wasn’t working when I tried it being disconnected. Mine is a 2013 Executive TDI with the dynaudio. Maybe the dynaudio has something to do with that? For others attempting this, I tapped into the canbus, power, and ground from behind the climate control. I used the file in post #203 as a guide. I put the red wire into fuse slot #15 on the passenger side fuse box as it is a switched fuse. You don’t need to remove the MMI from the glove box, you can acces everything needed when you drop the entire thing.
anyone?how do you wire it into the #15 slot?
Hello Ben, super write-up - thanks for sharing all that. I have a question on the dimming though. The head unit changes light intensity when not in carplay mode but it does not change it when in carplay. It's like the "lights on" info does not get relayed to it via joyeauto. Have I missed a wire when installing or is there a recent firmware that addresses this?"Maps brightness control" - the head unit will dim when the car's lights turn on
