I had a quick read through this forum about the issues people are having with the installation of their kits. A looooot of them seem to be installation based with poor support from the resellers. It's a shame really. I resell this type of product as well. I don't pretend that I have any part of the development but when it comes to supporting them I'm pretty decent. The device tries to emulate as close to what a factory delivered CarPlay option might be like. I believe they have reliably done a pretty good job considering the task, but it is important that expectations of the device are set before purchase and the installation, setup and handoff to the customer is done right as well. Because we are confident in the option we have decided to supply through CCS we sell our units with a 2 year warranty.
These are some issues I have seen while reading this thread.
"no music through AUX" - hadn't plugged in an AUX adaptor or incorrect installation of wiring harnesses
"Delay/double speak coming through to the other caller while I'm speaking/poor call audio" - delay calibration not set, yes this is a part of the setup procedure when installing the module
"Poor/no mic voice pickup on BT calls" - external microphone not installed correctly/incorrect placement, not plugged in properly
"No wifi set up/not connecting" - 100% user not knowing how to initiate the wireless connection
"Reverse select turns my screen black" - wrong dip switch setting
"External mic, why do I need it? Dodgy!" - Trust me, it's a much better option than trying to integrate 100's of different factory mics for Siri etc into a module plus better voice pickup when your phone decides to route the hands-free call through CarPlay instead of your factory BT.
"Can't use skip track on the steering wheel" - this is a relevant limitation of the Auto-iO as well. Skip can be selected on screen or if you play music via factory BT audio skip is possible. I will run you through how to make best use.
We had a user Signh that admitted they hadn't followed instructions to install it then went on and listed a bunch of issues, most that were installation based or ignoring recommendations for the module. This one pissed me off the most, even though it's not my product. Blatantly ignoring instructions then complaining about usability, ridiculous.
"Low res" - the aftermarket module won't upgrade the resolution of the factory screen
"Touch screen not responsive" - the factory touch screen is resistance based, not capacitive like your phone. It does take a little a more purposeful swiping technique to allow the module to respond to the actions, takes a couple of days to get the hang of it from experience. You will notice there are no swipe gestures in the factory UI but the aftermarket CarPlay module can still read a user's swipe and allows you to make them in the CarPlay menu, pretty impressive actually.
"Wireless CarPlay doesn't connect after walking away from the car for a minute" - the module goes to sleep when the car does, and when it wakes up it goes into a discoverable mode to find your phone. If it doesn't find a paired phone without 5 minutes or so it will stop looking. That means after you step out after driving for a while the module isn't looking for a phone and it hasn't gone to sleep yet when the car ignition is switched on again. There is a way to pair to the phone again after walking outside the range of the module Wifi that I will show you.
"Unit can lock up/black screen" - this is an issue with technology. Sometimes within a month, sometimes within a year or two. When a system is permanently powered up it gets no chance to power down. We install a small switch inline with the permanent power wire that allows a quick power cycle. Just like restarting a phone to clear a glitch, everything needs a rest, even if it is just for 10 seconds or so.
"Maps brightness control" - the head unit will dim when the car's lights turn on and CarPlay system automatically changes to dark mode on a system timer set by Apple. You can manually change the maps to dark mode if you want to set it on before the automatic timer mark. The fact that Maps doesn't switch to dark mode with car's lights turning on is a limitation of the device.
"Factory nav to CarPlay switching not working right, intermittent" - seems like a lot of the DIY guys are using positaps or some type of mechanical crimp connection. This is not recommended for a data connection due to the how specific the transmission needs to be at that level. We use a tap and solder joint and have never had a problem.
I hope that covers most of your concerns. Anything feel free to ask.
Cheers,
Ben - CCS
