Jack stand recommendation
5.3K views 5 replies 3 participants last post by  TurboABA
Hi all!
Will be working on my brakes pretty soon and want to put my '04 on a pair of jack stands for that.
Since the top of the stands are shaped like a V I'm not sure how stable they'll be if I put them in the ordinary jacking positions (more or less flat surface)... Any recommendations as to where to put them?
Thanks!
VD-CH
There are many ways to deal with this, depending on what you're placing them under.
I typically just grab a 1/2" piece of soft wood, which basically collapses once the vehicle is on it and provides both a "cushion" and a greater surface area as a contact point. You can make pads out of hockey pucks but cutting\grinding reliefs into them, use rubber liner, etc......
It all comes down to how much of the vehicle you're wanting to protect as well as how much non-slip contact surface you're after (if that's a concern).
