1 - 3 of 3 Posts
Have a 2005 V8 and purchased a Tow Bar (OEM) from a wrecker here in Melbourne. After consulting Dr. Google, fitted the Bar OK.
It came with a loom from the 7 pin flat Trailer connector with two plugs/sockets on the end, one goes into a module (not sure what this does) and the other seems to fit a socket just in the well under the CD player. Please see photos. The plug with the red tag is the one that is attached to the 7 pin Connector. The Green socket is existing.
I haven't traced the wires out yet to see where they go. Thought I would ask first.
Question is, is there a hidden plug for the other outlet on the module, or do I need a cable to fit and where does it go after that?
233180
233181
The trailer controller sits in front of the CD player, see below. You will have to remove the rest of the panel to access the location.
Thanks spyker, I ca see the plug but can't get to it.
Some panel removal needed.
Thanks again.
1 - 3 of 3 Posts
