Is This Normal?
5.7K views 22 replies 12 participants last post by  xoxKarly
If it were to be serious, you would smell something wrong. From the looks of it i'd have to go with a coolant leak, but if you can't smell coolant it most likely isn't. I've never had this problem with my Touareg before, only time it really steam's is when I take it out after a good car wash in below zero tempatures and the steam comes out of the grill from water leaking under the hood from the windshield. From the sounds of your vehicle, you might need an oil change or perhaps a tune-up? Unless it was cold, then that sound is normal. Not too sure, but if you left it out all night in the cold the sound is normal, and in that case ice and/or snow may have fallen under your hood which could have caused some steam from landing on your engine.
That sounds rough, I never saw a V10 that sounded like that but then again it was cold outside and my V8 gets a little loud when I keep it outside as well. I just read all the previous posts, and it was still full of suggestions so I thought i'd throw mine out there : )
