1 - 7 of 7 Posts
The warning beep while opening the hatch seems pretty unnecessary and I think it’s annoying. Is there a way to code this off with VCDS?
Thanks for any and all help.
Yes, in Adaptation you can turn it on and off, when it comes on (opening, closing, from door switch, fob, hatch switch, etc) the volume, and the pitch. You could try turning the volume down first, or having it come on only when opening from the fob or door switch. I keep mine on with lowered volume just incase someone is standing behind it when i open it.
Reactions: Singh and Steve_L
Oh ok.. thanks a bunch. I will have to check it out. Maybe turning it down will be ok. I am just glad it’s can be adjusted.
So is it under volume of acoustic warning? it has activated. So should I deactivate that? It requires a security code to deactivate that.
1 - 7 of 7 Posts
