Hi Guys
1st post here, but no stranger to forums! I actually owned and ran a KTM motorcycle forum for a few years! So to introduce myself. I have just moved over from Europe to Colorado! I decided to buy a Touareg as I have been a VW owner quite a few times, always Golfs, a Mk2 and 2 x Mk4s already. I managed to find a 2004 Touareg V8 that only had a genuine 52k miles on it at a really good price. I drove it around for 2 faultless weeks, the second of which we had about a foot of snow. Such a lovely SUV to drive and makes my old 07 Santa Fe feel rubbish! A couple days after the snow, I drove home for lunch, parked up had lunch and came back to the treg, turned the ignition and a lot of errors came up, including "brake fault stop vehicle" and "fault running gear workshop". So the treg is locked in park.
I've searched the forums and found a few posts on likely causes (failing battery and corroded wire splices seem the two most likely). I lifted the drivers side carpet and found a lot of water in there, sponge quite saturated with it. Access to the wiring loom was not too great but I managed to solder all the splices I could find (triple green splice, double black (thin), double brown, triple red/yellow). There was a double black (fat) wire splice that still seemed fine and my soldering iron wasn't hot enough to solder that huge splice anyways. Nevertheless none of these made a difference. All errors still there.
VCDS-Lite list is at the bottom of the post.
Tomorrow I am going to tilt the drivers seat back using my newly acquired 10mm triple square socket...and have a better look under the carpet to see if there are any splices I missed, wire faults, or obvious water damage to electrics. If theres nothing obvious, I may swap the battery as I have no idea of knowing how old it is.
Is it okay to disconnect the battery without any charger or spare power source to the car? will it reset or damage anything (don't really care about settings)
If any of you super knowledgable guys out there have any other tips or ideas, I'd love to hear them!
Thanks in advance!!!
Seth
VCDS-Lite Version: Release 1.2
Friday, 12 February 2016, 19:23:20:53436
Chassis Type: 7L - VW Touareg
Scan: 01,02,03,05,06,08,09,11,15,16,17,19,1C,22,29,34,36,37,39,45,46,47,55,56,65,68,6E,77
Address 01: Engine Labels: 077-907-560-AXQ.LBL
Controller: 4D0 907 560 DA
Component: 4.2L V8/5V G 0050
Coding: 0007875
Shop #: WSC 20108
VCID: 68A3EB1F1B6B
5 Faults Found:
18053 - Powertrain Data Bus: Missing Message from AWD Controller
P1645 - 008 - Implausible Signal
18005 - Powertrain Databus: Missing Message from Level Control System (J197)
P1597 - 008 - Implausible Signal
18034 - Powertrain Data Bus: Missing Message from TCU
P1626 - 008 - Implausible Signal
17837 - Circuit for Brake Vacuum Pump: Open Circuit
P1429 - 004 - No Signal/Communication
18057 - Powertrain Data Bus: Missing Message from ABS Controller
P1649 - 008 - Implausible Signal
Readiness: 0110 1101
Address 05: Acc/Start Auth. Labels: None
Controller: 3D0 909 135 M
Component: Kessy 6400
Coding: 0131304
Shop #: WSC 31414
VCID: 2F114003FE05
6 Faults Found:
01315 - Transmission Control Module
01316 - ABS Control Module
00576 - Terminal 15
009 - Open or Short to Ground
00185 - Control Circuit; Relay for Supply Voltage Terminal 15
00180 - Access/Start Authorization Antenna; Passenger Side (R135)
011 - Open Circuit
01299 - Diagnostic Interface for Data Bus (J533)
013 - Check DTC Memory
Address 06: Seat Mem. Pass Labels: None
Controller: 7L0 959 760
Component: Sitzverstellung 0701
Coding: 0000000
Shop #: WSC 00000
VCID: F7813863C6D5
1 Fault Found:
01330 - Central Control Module for Central Convenience (J393)
Address 08: Auto HVAC Labels: None
Controller: 7L6 907 040 D
Component: CLIMAtronic R/L X 2714
Coding: 0001030
Shop #: WSC 31414
VCID: 3115467BE831
2 Faults Found:
01592 - Air Quality Sensor (G238)
010 - Open or Short to Plus
Address 09: Cent. Elect. Labels: None
Controller: 7L6 937 049 K
Component: 2702
Coding: 0105694
Shop #: WSC 20108
VCID: 44FB1FAF4783
6 Faults Found:
01336 - Data Bus for Comfort System
01333 - Door Control Module; Rear Left (J388)
00907 - Intervention load Management
000 - -
01964 - Control Module for Seat & Steering Column Memory (J136)
01520 - Rain and Light Recognition Sensor (G397)
008 - Implausible Signal - Intermittent
Address 16: Steering wheel Labels: 7L6-953-549.LBL
Controller: 7L6 953 549 C
Component: Lenksäulenmodul 3201
Coding: 0000232
Shop #: WSC 31414
VCID: 3FF110432E65
1 Fault Found:
00457 - Control Module for Network (J519)
Address 17: Instruments Labels: None
Controller: 7L6 920 980 D
Component: KOMBIINSTRUMENT RB4 2835
Coding: 0007231
Shop #: WSC 20108
VCID: 39057E5B3041
9 Faults Found:
01310 - Level Control System Control Module (J197)
02053 - Control Module for Transfer Case (J646)
01335 - Drivers Seat/Mirror Position Control Module (J543)
00470 - Combination comfort Databus in Single Wire
011 - Open Circuit - Intermittent
Address 19: CAN Gateway Labels: 6N0-909-901-19.LBL
Controller: 6N0 909 901
Component: Gateway K<>CAN 0101
Coding: 0000006
Shop #: WSC 31414
VCID: F093037FA3BB
10 Faults Found:
00778 - Steering Angle Sensor (G85)
Address 1C: Level Sensing Labels: 7L6-919-879.LBL
Controller: 7L6 919 879
Component: JCI PathPoint 1600
Coding: 0000000
Shop #: WSC 00000
VCID: 047BDFAF0703
No fault code found.
Address 29: Left Light Labels: None
Controller: 3D0 909 157
Component: EVG GDL+AutoLWR(l) X012
Coding: 0000003
Shop #: WSC 31414
VCID: E6BF6527917F
Address 36: Seat Mem. Drvr Labels: None
Coding: 0000000
Shop #: WSC 00000
VCID: F7813863C6D5
4 Faults Found:
01331 - Door Control Module; Driver Side (J386)
01332 - Door Control Module; Passenger Side (J387)
01317 - Control Module in Instrument Cluster (J285)
Address 37: Navigation Labels: None
Controller: 7L6 919 887 A
Component: Navigation 0635
Coding: 0000002
Shop #: WSC 31414
VCID: 44FB1FAF4783
Address 39: Right Light Labels: None
Controller: 3D0 909 158
Component: EVG GDL+AutoLWR(r) X012
Coding: 0000003
Shop #: WSC 31414
VCID: E7A168239675
Address 46: Central Conv. Labels: 7L0-959-933.LBL
Controller: 7L0 959 933 C
Component: B0 HSG 0102
Coding: 0000085
Shop #: WSC 20108
VCID: 3C0B674F3F73
11 Faults Found:
00576 - Terminal 15
01312 - Powertrain Data Bus
00928 - Locking Module for Central Locking; Front Driver Side (F220)
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
00930 - Locking Module for Central Locking; Rear Left (F222)
01334 - Door Control Module; Rear Right (J398)
00931 - Locking Module for Central Locking; Rear Right (F223)
Address 47: Sound System Labels: None
Controller: 7L6 035 466
Component: 12K-AUDIOVERST 0108
Coding: 0000000
Shop #: WSC 00000
VCID: F195067BA8B1
Address 56: Radio Labels: None
Controller: 7L6 035 186 A
Component: Radio 0635
Coding: 0005055
Shop #: WSC 31414
VCID: 3115467BE831
Address 65: Tire Pressure Labels: 7L6-907-273.LBL
Controller: 7L6 907 273
Component: Reifendruckueberw. 0052
Coding: 0110390
Shop #: WSC 20108
VCID: F59D326BDCD9
2 Faults Found:
01521 - Sensor for Tire Pressure
Address 68: Wiper Electr. Labels: None
Controller: 7L0 955 119 F
Component: Front Wiper 2416
Coding: 0000004
Shop #: WSC 31414
VCID: 370178630655
1 Fault Found:
Address 6E: Ctrl Head Roof Labels: 7L6-919-044.LBL
Controller: 7L6 919 044 C
Component: DACHDISPLAY 0529
Coding: 0000000
Shop #: WSC 31414
VCID: 370178630655
1 Fault Found:
02607 - Control Module (Relay?) for Aux. Water Heater (J737)
End --------------------------------------------------------------------------------------------------
Seth
Coding: 0007875
Shop #: WSC 20108
VCID: 68A3EB1F1B6B
5 Faults Found:
Coding: 0131304
Shop #: WSC 31414
VCID: 2F114003FE05
6 Faults Found:
00576 - Terminal 15
011 - Open Circuit
Coding: 0000000
Shop #: WSC 00000
VCID: F7813863C6D5
1 Fault Found:
Coding: 0001030
Shop #: WSC 31414
VCID: 3115467BE831
2 Faults Found:
Component: 2702
Coding: 0105694
Shop #: WSC 20108
VCID: 44FB1FAF4783
6 Faults Found:
000 - -
Coding: 0000232
Shop #: WSC 31414
VCID: 3FF110432E65
1 Fault Found:
Coding: 0007231
Shop #: WSC 20108
VCID: 39057E5B3041
9 Faults Found:
Coding: 0000006
Shop #: WSC 31414
VCID: F093037FA3BB
10 Faults Found:
Coding: 0000000
Shop #: WSC 00000
VCID: 047BDFAF0703
Coding: 0000003
Shop #: WSC 31414
VCID: E6BF6527917F
Coding: 0000000
Shop #: WSC 00000
VCID: F7813863C6D5
4 Faults Found:
Coding: 0000002
Shop #: WSC 31414
VCID: 44FB1FAF4783
Coding: 0000003
Shop #: WSC 31414
VCID: E7A168239675
Coding: 0000085
Shop #: WSC 20108
VCID: 3C0B674F3F73
11 Faults Found:
00576 - Terminal 15
Coding: 0000000
Shop #: WSC 00000
VCID: F195067BA8B1
Coding: 0005055
Shop #: WSC 31414
VCID: 3115467BE831
Coding: 0110390
Shop #: WSC 20108
VCID: F59D326BDCD9
2 Faults Found:
Coding: 0000004
Shop #: WSC 31414
VCID: 370178630655
1 Fault Found:
Coding: 0000000
Shop #: WSC 31414
VCID: 370178630655
1 Fault Found:
