1 - 6 of 6 Posts
Hi!
Enjoy:
Some minutes after start and when ventilation is on, this noise (ticking + creaking) comes from the dashboard (driver side) without any regularity (sometimes for a few seconds, sometimes the whole trip).
Do you have any idea?
Sounds like one of the flaps is trying to move but can't.
Have you tried altering the various settings on the HVAC system to see if it makes a difference when this noise is happening?
Yes, I switched on/off the AC and/or air recirculation, changed temperature, source (front/bottom), intensity…
It seems that no particular setting can avoid this noise (aside from a full power off).
You need to run a scan using VCDS to see what faults are logged.
You have an issue with one of the servo motors (flap controller) it is either jammed or broken and can't reach its proper position (limit switch) it therefore continue to retry the requested action.
To confirm this leave the key turned on ( as in your video) and turn the unit off. The noise should stop. On the 4 Zone units this is done by selecting the lowest fan speed on the drivers side when all controls are off the drivers side (button). Not sure exactly how it works on the 2 zone.
I have attached the Self Study Guide for the Heating/AC which may help diagnose the offending controller.
Stuart...
Discussion Starter · #6 ·
Thanks for the Self Study, @hedditch!
I had it on my hard drive but totally forgot. :oops:
As I said, the noise stops when fan is off.
So yes, it should come from the left footwell flap V108.
I will investigate on this side.
@noobytoogy, you're right. A VCDS check can't be a bad thing to do.
I just need to buy a cable prior to that. :mrgreen:
1 - 6 of 6 Posts
