1 - 20 of 22 Posts
Hey guys! I recently started playing with VCDS tweaks on my 16’ TDI Executive and have an issue now. The back up camera is inoperable and the “Parking Distance Warning System” states “The Function Is Currently Not Available” when trying to access from the RNS 850. Also putting the car reverse gives me the beep, parking mode button illuminates, but no camera on the screen.
Yes, I’m well aware I should have copied all my original coding before playing around but I didn’t and now I suffer the consequences.
I did go through all the tweaks again but still no dice. No fault codes present on any modules.
If I had to guess it is a “Green Screen” configuration issue or something I did in the Park/Steer Assist controller.
Looking for someone with the same or similar model that would be willing to share that current coding so I can compare. Everything else works great, but I would be nice to have the backup camera and other cameras working again. 🤦‍♂️
Full Autoscan; Friday,17,March,2023,07:59:20:04687VCDS -- Windows Based VAG/VAS Emulator Runn - Pastebin.com
Here are some images of the coding I think I fudged up:
Which of the 17 show what I don't see?
Friday,17,March,2023,08:00:15:04687
VCDS Version: 23.3.0.0 (x64) HEX-NET2 CB: 0.4631.5
Data version: 20230228 DS346.1
www.Ross-Tech.com
Dealer/Shop Name: RevTech Performance, LLC
VIN: WVGEP9BP2GD002010 License Plate:
Chassis Type: BP-VW52 (7P6)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 36 3C 42 46 47 52 53 55
56 5F 62 65 69 6C 6D 72 85 8B 8E
VIN: WVGEP9BP2GD002010 Mileage: 138431km-86017miles
01-Engine -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
3C-Lane Change -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
69-Trailer -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
85-On Board Cam. -- Status: OK 0000
8B-Adaptive Cruise 2 -- Status: OK 0000
8E-Image Processing -- Status: OK 0000
Address 01: Engine (J623-CNRB) Labels:. 059-907-401-V2.clb
Part No SW: 7P1 907 401 C HW: 7P0 907 401 K
Component: 3.0TDI FSA H21 0010
Revision: 56H21--- CVN: AF4B74E5D45710C1755A21130E1FC39E
Coding: 292A4012237600050000
Shop #: WSC 03999 780 00200
ASAM Dataset: EV_ECM30TDI0117P1907401C 001011
ROD: EV_ECM30TDI0117P1907401C.rod
VCID: 30327E0A1AA2777ABF3-8064
VINID: 9E65D58094A009750000200100455373BB
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans (J217) Labels: 0C8-927-7XX-V2.clb
Part No SW: 0C8 927 755 R HW: 0C8 927 755
Component: AL1000 AISIN 130 3374
CVN: E0C27B10
Coding: 010500000C008400000000000000000000000000
Shop #: WSC 01232 002 104857
ASAM Dataset: EV_TCMAL991031 003118
ROD: EV_TCMAL991031_003.rod
VCID: 40D22ECAAA02E7FA4F3-8014
Address 03: ABS Brakes (J104) Labels:* 7P0-907-379.clb
Part No SW: 7P0 907 379 R HW: 7P0 907 379 A
Component: MK25A H37 0521
Revision: -------- Serial number: 41505440289324 Dataset Number: 7P0012v____ 0001
Coding: 5B7613C349246F55DAF4C89492D2F6607301
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_MK25AXT 010001
ROD: EV_ESPMK25A01000.rod
VCID: 4CCA0AFA964A339AA3B-8018
Part No SW: 4H0 907 064 GK HW: 4H0 907 064 GK
Component: BCM2 2.0 H37 0572
Revision: 00002001
Coding: 0D860016000000000000
VCID: 78A2862AB2D26F3A373-802C
Subsystem 1 - Part No SW: 7P6 959 754 AR HW: 7P6 959 754 AR
Component: FBSTOUAREGIDG H08 0084
Serial number: 3615000138212004
Subsystem 2 - Part No SW: 4H0 905 852 B HW: 4H0 905 852 B
Component: J764 ELV MLB H40 0046
Serial number: 3215000088325012
Address 08: Auto HVAC (J255) Labels:| 7P6-907-040.clb
Part No SW: 7P6 907 040 CN HW: 7P6 907 040 CN
Component: Klima 2 Zonen H23 1507
Coding: B686200A80
VCID: 0256E4C2E48E35EA197-8056
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V2.clb
Part No SW: 4H0 907 063 DA HW: 4H0 907 063 AA
Component: BCM1 2.0 H20 0311
Revision: 22020001 Serial number: 00001099301402
Coding: 26004016963C5D010020480480005D4C431C6608A2014265800000008040110000000000000000
VCID: 6A86AC62FC7ECDAAB17-803E
Component: WWS 150602 033 0021
Serial number: 90243400150609100719
Coding: 004DBD
Subsystem 2 - Part No SW: 7P0 955 559 E HW: 7P0 955 559 E Labels: 8K0-955-559.CLB
Component: RLFS H10 0020
Serial number: 20583326
Coding: 025223
Subsystem 3 - Part No SW: 7P6 941 431 AC HW: 7P6 941 431 AC
Component: E1 - LDS H02 0040
Serial number: 00000000000406150332
Subsystem 4 - Part No SW: 4G0 907 410 A HW: 4H0 907 410 A
Component: USHL4.2 H30 0030
Serial number: 00000000095Z01F239C7
Subsystem 5 - Part No SW: 8K0 959 772 E HW: 8K0 959 772
Component: SLR-B8 H06 0007
Serial number: 0130998282
Coding: 952F00
Subsystem 6 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Serial number: WA120820000013177539
Coding: 010300
Address 10: Park/Steer Assist (J446) Labels:| 7P6-919-475.clb
Part No SW: 7P6 919 475 D HW: 7N0 919 475
Component: PARKHILFE 8K H06 0030
Revision: -------- Serial number: 28231515601028
Coding: 510D04
ASAM Dataset: EV_VW526ParkiAssis2 001013
ROD: EV_VW526ParkiAssis2.rod
VCID: 44DA22DABE1AFBDA6BB-8010
Address 13: Auto Dist. Reg (J428) Labels:| 4H0-907-561.clb
Part No SW: 7P6 907 561 C HW: 7P6 907 561
Component: ACC3 H21 0400
Serial number: 00000000000000
Coding: 3701010101
ASAM Dataset: EV_AdaptCruisContrVW526 002012
ROD: EV_AdaptCruisContrVW526_002.rod
VCID: 3C2A5A3AC6EA831A13B-8068
Address 15: Airbags (J234) Labels:| 7P0-959-655.clb
Part No SW: 7P0 959 655 F HW: 7P0 959 655 F
Component: VW10Airbag02B H10 0044
Revision: -------- Serial number: 003S80005C0D Dataset Number: 7P6003V____ 1733
Coding: 000000000000000000000000000000003242
ASAM Dataset: EV_AirbaVW10BPAVW526 002001
ROD: EV_AirbaVW10BPAVW526_002_VW52.rod
Seat occupied recognition:
Serial number: 5850000R153030MHDL
Serial number: 3575LRB405336CAM61P4
Front Passenger's Side Airbag Crash Sensor:
Serial number: 3585LRB405D3AVPA7PTR
Rear Side Airbag Crash Sensor (on driver's side):
Serial number: 3517ARB405339P82F0T
Passenger side rear thorax airbag crash sensor:
Serial number: 3527ARB405339P8248T-
Serial number: 3557BRB40573EENAH8OQ
Serial number: 3567BRB40573EENA60C$
Address 16: Steering wheel (J527) Labels:. 4H0-953-568.clb
Part No SW: 4H0 953 568 M HW: 7P6 953 507 AJ
Component: Lenks.Modul H06 0005
Revision: -------- Serial number: 01374OFB00086
Coding: 000CDD
VCID: 3D2C573EDD708A12245-8068
Subsystem 1 - Part No SW: 7P6 959 542 A HW: 7P6 959 542 A
Component: E221__MFL-TAS H04 0028
Serial number: 0091356 TRW 20150513
Address 17: Instruments (J285) Labels:| 7P6-920-xxx-17.clb-SRI1
Part No SW: 7P6 920 983 D HW: 7P6 920 983 D
Component: Kombi H13 0515
Revision: 13240302 Serial number: 658130615592017
Coding: 835733026F08CF05020004
ASAM Dataset: EV_KombiUDSRBVW526 001022
ROD: EV_KombiUDSRBVW526.rod
Address 19: CAN Gateway (J533) Labels:* None
Part No SW: 7P6 907 530 N HW: 7P6 907 530 G
Component: GW-CAN-L-FR-M H13 6042
Revision: -------- Serial number: 00000001892562 Dataset Number: 7P6067v____ 0041
Coding: 000103AD00
GVL: FB5F40655D7F680000
ASAM Dataset: EV_GatewVW526UDS 001007
ROD: EV_GatewUDS_VW52.rod
VCID: 43D821C6BB14FCE2521-8016
Subsystem 1 - Part No SW: 7P0 915 181 B HW: 7P0 915 181
Component: Batt_Sensor H07 0190
Serial number: 32153G02325701182075
2 Faults Found:
12290 - Quiescent Current
U1406 00 [008] - Too High
Freeze Frame:
Fault Status: 00000001
Fault Priority: 7
Fault Frequency: 2
Reset counter: 203
Mileage: 138431 km
Date: 2023.03.17
Time: 00:15:48
Voltage terminal 30: 12.1 V
Voltage terminal 15: 0.0 V
Control Module temperature: 26 °C
System status: LIN_active
IN ESP_standstill flag: no standstill detected
Engine running: OFF
IN ZAS_Te_X: OFF
Terminal 15 status via CAN: OFF
Terminal 15 status: OFF
Datenfeld: 0
12291 - Energy Management Active
U140B 00 [008] - -
[Powermanagement active]
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 203
Mileage: 138431 km
Date: 2023.03.17
Time: 03:16:14
Voltage terminal 30: 12.0 V
Control Module temperature: 21 °C
System status: Awake_Timer_active
Engine running: OFF
IN ZAS_Te_X: OFF
Datenfeld: 1
Address 36: Seat Mem. Drvr (J136) Labels: None
Part No SW: 4H0 959 760 E HW: 4H0 959 760 E
Component: MEM-FS H08 0156
Revision: AA000000 Serial number: 00000152549168
Coding: C0581B0015004001000001010101202020202121202020
VCID: 353C4F1EE5405252EC5-8060
Address 3C: Lane Change (J769) Labels:| 5Q0-907-566.clb
Part No SW: 7P6 907 566 A HW: 4H0 907 566 F
Component: SWA Master H06 0021
Serial number: 0369594297 Dataset Number: 7P6764V____ 0009
Coding: 030221
ASAM Dataset: EV_LaneChangAssis 001028
ROD: EV_LaneChangAssis_VW51.rod
VCID: 3FD02D36D7FC9802369-806A
Lane change assistance control module 2:
Subsystem 1 - Part No SW: 7P6 907 568 A HW: 4H0 907 568 F
Component: SWA Slave H06 0021
Serial number: 0370247890
Coding: 030221
Address 42: Door Elect, Driver
Cannot be reached
Address 46: Central Conv. (J393) Labels:. 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0370323933
Coding: 01871E3A68B9509582A00620210A18000000000000000000000000000000
Subsystem 1 - Part No SW: 7P6 959 719 A HW: 7P6 959 719 A
Component: GTO BT H20 0059
Serial number: 149154345
Subsystem 2 - Part No: 1K0 951 605 C
Subsystem 3 - Part No SW: 7P0 959 591 D HW: 6R0 959 591 D
Component: J245 PS30.408 H03 0004
Serial number: 0000FST000CJLIY00000
Coding: 191100
Subsystem 4 - Part No SW: 7P0 959 591 E HW: 8V3 959 591 A
Component: J394 PS30.408 H03 0004
Serial number: 0000FST000CZF8Y00000
Coding: 191100
Subsystem 5 - Part No SW: 3AA 962 243 E HW: 3AA 962 243 E
Component: GEB.F.Heckoef H16 0813
Serial number: 65023078
1 Fault Found:
01134 - Alarm Horn (H12)
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 2
Fault Frequency: 1
Reset counter: 163
Mileage: 138431 km
Time Indication: 0
Date: 2023.03.16
Time: 20:56:09
Address 47: Sound System (J525) Labels:. 8T0-035-223-BOM.clb
Part No SW: 7P6 035 466 HW: 7P6 035 466
Component: DSP Prem H01 0090
Revision: 00001001 Serial number: 10811002643408
VCID: 75BC8F1EA5C012522C5-8020
Address 52: Door Elect, Pass. (J387) Labels:. 4H0-959-792.clb
Part No SW: 4H0 959 792 S HW: 4H0 959 792 M
Component: TSG BF H02 0306
Revision: -------- Serial number: 0000154203844
Coding: 011D17205E00453005080000
VCID: 48C236EA82B2DFBA873-801C
Address 53: Parking Brake (J540-) Labels:| 7P0-907-801.clb
Part No SW: 7P0 907 801 F HW: 7P0 907 801 F
Component: EPB H51 1201
Revision: 00000000 Serial number: C1561700752 Dataset Number: A001
Coding: 01040200
ROD: EV_ParkbA7.rod
VCID: 363E4812F8C6594AE5F-8062
Slave 3:
Address 55: Headlight Range (J745) Labels:| 7P6-907-357.clb
Part No SW: 7P6 907 357 C HW: 7P6 907 357 B
Component: AFS-ECU H01 0110
Revision: -------- Serial number: -------------- Dataset Number: 7P0036v____ 0017
Coding: 012A02010B000400
ASAM Dataset: EV_HeadlRegulAFSMQBMLB 001001
ROD: EV_HeadlRegulAFSMQBMLB_VW52.rod
Left Headlamp Power Output Stage:
Subsystem 1 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0005
Coding: B00000
Right Headlamp Power Output Stage:
Subsystem 2 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0005
Coding: B00000
Address 56: Radio (R) Labels:. 4F0-035-0xx-56.clb
Part No SW: 4G0 035 082 G HW: 4G0 035 082
Component: Radio U SIRIU H66 0133
Revision: AB001007 Serial number: 156F 0F8280182
Coding: 020007010000000001
VCID: 241A825A5EDADBDA4BB-8070
Part No SW: 7P6 035 664 K HW: 7P6 035 664 A
Component: H-BN-NA H41 0933
Revision: -------- Serial number: 606FP0F7500004
Coding: 020200060040E9FF7F0A3F0E80000003F00001030300000000
VCID: 40D22ECAAA82E7FA4F3-8014
Subsystem 1 - Part No: 7P6 060 884 B
Component: NAR 2015 1202
Subsystem 2 - Part No SW: 7P6 919 603 L HW: 7P6 919 603 L
Component: DU8 SV Touch H56 0046
Serial number: VWZ8Z9RGG00106
Subsystem 3 - Part No SW: 7P6 919 603 L HW: 7P6 919 603 L
Subsystem 4 - Part No: 8R0 060 961 G
Component: CD-Database 6208
Address 62: Door, Rear Left (J388) Labels:. 4H0-959-795.clb
Part No SW: 4H0 959 795 P HW: 4H0 959 795 J
Component: TSG HL H03 0306
Revision: -------- Serial number: 0000153647672
Coding: 011817200000253005080000
Part No SW: 7P6 907 273 L HW: 5Q0 907 273
Component: RDKBERU30 H04 0003
Serial number: 40000000018197 Dataset Number: 7P6096V____ 0029
ASAM Dataset: EV_RDKBERU30 005005
ROD: EV_RDKBERU30_005.rod
VCID: 45DC3FDEB520C2D27C5-8010
Address 69: Trailer (J345) Labels:| 4H0-907-383-V2.clb
Part No SW: 4H0 907 383 M HW: 4H0 907 383 K
Component: Anhaenger H20 0160
Revision: 7C001003 Serial number: 0370943514 Dataset Number: 7P0124v____ 0008
Coding: 0200000200000000
ASAM Dataset: EV_TrailFunctGener2Hella 001005
ROD: EV_TrailFunctGener2Hella_VW52.rod
VCID: 37204516FFCCA042FE9-8062
Address 6C: Back-up Cam. (J928) Labels:| 7P6-907-441-V1.clb
Part No SW: 7P6 907 441 G HW: 7P6 907 441 G
Component: TopView H08 0115
Revision: 11001001 Serial number: 82330JF0236681
Coding: 0100000000010000010102000000
ASAM Dataset: EV_CamerSysteTopViewVW 001014
ROD: EV_CamerSysteTopViewVW.rod
VCID: 3D2C573EDDF08A12245-8068
Address 6D: Trunk Elect. (----) Labels:| 7N0-959-107.clb
Part No SW: 7P6 959 107 C HW: 7P6 959 107
Component: HDSG-Modul H10 0043
Revision: 22010001 Serial number: 160500010 Dataset Number: 7p0771v____ 0012
Coding: 0533314003
ASAM Dataset: EV_HeckkTouar 202142
ROD: EV_HeckkTouar.rod
Address 72: Door, Rear Right (J389) Labels:. 4H0-959-795.clb
Component: TSG HR H03 0306
Revision: -------- Serial number: 0000153647270
Address 85: On Board Cam. (J852) Labels:| 7P6-907-217.clb
Part No SW: 7P6 907 217 B HW: 7P6 907 217
Component: DPC-SG H26 0035
Revision: -------- Serial number: 262130025421000 Dataset Number: 7P0EZ1v____ 0024
Coding: 69020000
ASAM Dataset: EV_OnBoardCamerDTR 001001
ROD: EV_OnBoardCamerDTR.rod
VCID: 3924432EC9D8B63208D-806C
Slave 1:
Subsystem 1 - Part No: 7P6 907 658
Component: NICKRATENSENS H02 0001
Serial number: 000000007065467_3114
Address 8B: Adaptive Cruise 2 (J428) Labels:| 4H0-907-561.clb
Part No SW: 7P6 907 541 C HW: 7P6 907 541
Coding: 3701010101
ASAM Dataset: EV_AdaptCruisContr2VW526 002011
ROD: EV_AdaptCruisContr2VW526_002.rod
VCID: 3A265C22CCDEBD2A017-806E
Address 8E: Image Processing (J851) Labels:| 7P6-907-107.clb
Part No SW: 7P6 907 107 B HW: 7P6 907 107
Component: BV-SG H33 0035
Serial number: 005000010206157
Coding: 0AA118040000
ASAM Dataset: EV_BTR 002001
ROD: EV_BTR_002.rod
End----------(Elapsed Time: 02:49, VBatt start/end: 14.6V/14.6V)-----------
'14 TDI Execline
Nothing about coding jumps out at me, but....
Looks like your battery is low and EMS has stepped in.
Look at your battery stats.
Evaluate your battery history.
Fully charge your battery and clear the codes.
Scan again to see what's still there with sufficient juice present.
Not trying to be 'that guy' but stop messing around with an extremely powerful system if you don't know what you're doing
Discussion Starter · #8 ·
Just replaced the battery and have not coded yet... Thanks for looking through the autoscan!
Discussion Starter · #9 ·
All good man... I've been playing around with Audi/VW since 2002, not my first rodeo. It is the first time I decided to not copy down my original coding though. I'm a sucker for pain. haha
'14 TDI Execline
It's a shame that after "all that experience" you started with the dumbest possible approach.....
Also can't understand why you didn't code the battery after replacing it.
Also, did you "literally" just replace the battery prior to scanning.... because the FF data on that fault is FRESH
:unsure:
Discussion Starter · #11 ·
:unsure:
Oh believe me I know... I'm kicking myself in the ass over this stupid mistake. I didn't code the battery because a friend was borrowing my cable. Been a week or longer...
Ah I feel that to my bones. Carry on 🥂
  • Haha
Reactions: madmycal
Hi Madmycal,
No idea if this will help but it’s from my 2015 TDI Execline.
Revision: -------- Serial number: 28291510304493
Coding: 518D04
VCID: 44D142BFBE1EAECB8FA-8010
Discussion Starter · #19 ·
No luck yet... Still poking around.
Park/Steer Assist:
Existing 10 - 510D04
Tested 10 - 318501
Information Electronics:
Existing 5F - 020200060040E9FF7F0A3F0E80000003F00001030300000000
Tested 5F - 020200050040E9EF79022B0E00000003F00001030000000000
Tested 5F - 020200050040E1EF41022B0E00000003F00001030000000000
Discussion Starter · #20 ·
UPDATE:
Camera system works again... Not exactly sure what fixed it though. I did recode the battery and got rid of the low voltage codes - cameras still inoperable. I played around with my green screen settings some more and went back through and reverted all the VCDS tweaks - cameras still inoperable.
The car sat over night and I went on a short road trip the next day... During the road trip at a gas station I put the car in reverse and suddenly I have all my cameras again. :unsure:
Very strange issue, but happy its all sorted for now.
Thank you all for your assistance!
1 - 20 of 22 Posts
