Immobilizer Help!!!
1.6K views 19 replies 5 participants last post by  TeeDeeEye6
Hello, my father recently purchased a 2009 treg v6tdi from auction, curtain airbags went off put car in in great shape, the car came with no key.
We got a key engraved from dealer no fob buttons programmed tho, looked on tunezilla for an immo delete, took the ECU to TooQuicks , a vag specific mechanic and got the immobilizer delete. After the delete, I put the key in ignition and try to start but no lights come on the dash and the car doesn't even crank. but the "immobilizer active" icon displays in the MFD. any help because we are stuck and tons of money into this car😬
After you wipe the immobilizer from the ecu, occasionally the light turns on with zero drivable type issues and a code clear will shut it off for a long while. This doesn't sound like that... sound like a key code issue was performed wrong, that said. Good luck.
I have to ask, just because no one else has yet.
Why didn't you just get the key cut and the FOB programmed for the vehicle?
You're probably too far down the rabbit hole now but I just have to ask.
We could only get the keys cut through dealer, but we cannot get the car on the trailer because the wheels are turned. All we need to do is get that steering wheel to unlock so we can get it on the trailer. Any help?
UPDATE!! We were able to turn the car over and get it moving. All we did was jump the cluster fuse to power and go under the hood and press the relay to start the engine. To shift it into gear, you have to touch the relay under the seat. We got the steering column lock off and we think that is the problem. We are now able to steer the car with power steering, just the key still does not work with the ignition. Nothing in the interior works while the car is on as of Windows, hvac, steering wheel functions. I also have some codes that maybe you guys can help determine the problem Immobilizer module: 00186-Control circuit; Relay for Supply Voltage Terminal 15SV 006 Short to Plus 00457 Central Electronics Control Module / BCM (J519) Acc/Start auth. Module: 00288 - Steering Column Lock Actuator (N360) 011 - Open Circuit 01049 - Supply Voltage Term 50 006 - Short to Plus 00576-Terminal 15 006 Short to Plus 01176 - Key 008 - Implausible Signal 00185 - Control Circuit; Relay for Supply Voltage Terminal 15 009 - Open or Short to Ground 00087 - Terminal 30 for Starting Relevant Consumers 002 - Lower Limit Exceeded 00668 - Supply Voltage Terminal 30 002 - Lower Limit Exceeded Going to auto scan tomorrow and give you guys a full readout. Thanks for the help again!
Reactions: Wagon8ter
Code:
Friday,12,July,2024,22:52:10:21044
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 24.5.0.0 (x64)  HEX-V2 CB: 0.4643.4
Data version: 20240429 DS355.0
www.Ross-Tech.com
VIN: WVGFM77L79D036017   License Plate:
Mileage: 119780km-74427mi   Repair Order:
Chassis Type: 7L (6N0)
Scan: 01 02 03 05 08 09 15 16 17 19 22 2E 37 46 47 55 56 65 68 69
          6C 6D 6E 76 77
VIN: WVGFM77L79D036017   Mileage: 119780km-74427miles
01-Engine -- Status: Malfunction 1010
02-Auto Trans -- Status: Cannot be reached 1100
03-ABS Brakes -- Status: Cannot be reached 1100
04-Steering Angle -- Status: Cannot be reached 1100
05-Acc/Start Auth. -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
22-AWD -- Status: Cannot be reached 1100
2E-Media Player 3 -- Status: Malfunction 0010
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
55-Headlight Range -- Status: Cannot be reached 1100
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: Malfunction 0010
65-Tire Pressure -- Status: Malfunction 0010
68-Wiper Electr. -- Status: OK 0000
69-Trailer -- Status: Malfunction 0010
6C-Back-up Cam. -- Status: Malfunction 0010
6D-Trunk Elect. -- Status: Malfunction 0010
6E-Ctrl Head Roof -- Status: Cannot be reached 1100
72-Door, Rear Right -- Status: Malfunction 0010
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: Malfunction 1010
Address 01: Engine (CAT)       Labels:. 059-907-401-CAT1.clb
   Part No SW: 7L0 907 401 T    HW: 7L0 907 401 K
   Component: 3.0TDI FSA  G004AG  0140
   Revision: 33H01---    Serial number: VWX3Z0H2826306
   Coding: 0421002A590F0968
   Shop #: WSC 11131 003 1048576
   VCID: 3C213D7ECA7E84AA4BB-5184
   VINID: 9E65D67471DC1C95000C60011C2E74CD1D
8 Faults Found:
049446 - No Communications with Steering Angle Sender (G85)
               U0126 - 000 -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 2
                    Fault Frequency: 12
                    Reset counter: 255
                    Mileage: 119782 km
                    Time Indication: 0
                    Date: 2024.05.22
                    Time: 01:02:38
             Freeze Frame:
                    RPM: 0 /min
                    Speed: 4.5 km/h
                    Voltage: 12.54 V
                    (no units): 0.0
                    Bin. Bits: 00000001
049441 - No Communication with ABS Brake Control Module
               U0121 - 007 -  - MIL ON
             Freeze Frame:
                    Fault Status: 11100111
                    Fault Priority: 2
                    Fault Frequency: 254
                    Reset counter: 255
                    Mileage: 119782 km
                    Time Indication: 0
                    Date: 2024.05.22
                    Time: 01:02:38
             Freeze Frame:
                    RPM: 0 /min
                    Speed: 4.5 km/h
                    Voltage: 12.54 V
                    (no units): 0.0
                    Bin. Bits: 00000001
049409 - No Communication with Transmission Control Module
               U0101 - 001 -  - MIL ON
             Freeze Frame:
                    Fault Status: 11100001
                    Fault Priority: 6
                    Fault Frequency: 11
                    Reset counter: 255
                    Mileage: 119782 km
                    Time Indication: 0
                    Date: 2024.05.22
                    Time: 01:02:38
             Freeze Frame:
                    RPM: 0 /min
                    Speed: 4.5 km/h
                    Voltage: 12.54 V
                    (no units): 0.0
                    Bin. Bits: 00000001
008381 - Control Circuit for Reductant Heating 2
               P20BD - 000 - Open Circuit - MIL ON
             Freeze Frame:
                    Fault Status: 11100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 119782 km
                    Time Indication: 0
                    Date: 2024.05.22
                    Time: 01:02:38
             Freeze Frame:
                    RPM: 0 /min
                    Speed: 4.5 km/h
                    Voltage: 12.54 V
                    Temperature: 19.8 C
                    Temperature: 44.1 C
                    Voltage: 0.000 V
                    Voltage: 0.000 V
000406 - Engine Oil Temp. Sensor (G8)
               P0196 - 006 - Implausible Signal
             Freeze Frame:
                    Fault Status: 01100110
                    Fault Priority: 2
                    Fault Frequency: 5
                    Reset counter: 255
                    Mileage: 119782 km
                    Time Indication: 0
                    Date: 2024.05.22
                    Time: 02:31:15
             Freeze Frame:
                    RPM: 0 /min
                    Speed: 4.5 km/h
                    Fuel Consump.: 0.00 l/h
                    Temperature: 32.4 C
                    Temperature: 26.1 C
                    Temperature: 28.8 C
                    Temperature: 26.1 C
005668 - MIL Request Signal Active (Check TCM for errors too!)
               P1624 - 000 -  - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 6
                    Fault Frequency: 5
                    Reset counter: 255
                    Mileage: 119782 km
                    Time Indication: 0
                    Date: 2024.05.23
                    Time: 06:11:15
             Freeze Frame:
                    RPM: 819 /min
                    Speed: 4.5 km/h
                    Voltage: 13.38 V
                    Temperature: 30.6 C
                    Temperature: 25.2 C
                    Absolute Pres.: 999.6 mbar
                    Torque: 183.3 Nm
002329 - Selector Lever
               P0919 - 000 - Malfunction - Intermittent
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 255
                    Reset counter: 255
                    Mileage: 119782 km
                    Time Indication: 0
                    Date: 2024.05.23
                    Time: 06:11:18
             Freeze Frame:
                    RPM: 777 /min
                    Speed: 4.5 km/h
                    Voltage: 13.53 V
                    Temperature: 30.6 C
                    Temperature: 25.2 C
                    Torque: 179.4 Nm
049428 - Control Module for All Wheel Drive Clutch
               U0114 - 001 - No Communication
             Freeze Frame:
                    Fault Status: 01100001
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 255
                    Mileage: 119782 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 0 /min
                    Speed: 0.0 km/h
                    Voltage: 10.87 V
                    (no units): 0.0
                    Bin. Bits: 00000001
Readiness: 1 3 0 0 1
Address 02: Auto Trans
Cannot be reached
Address 03: ABS Brakes
Cannot be reached
Address 05: Acc/Start Auth.        Labels: None
   Part No SW: 7L0 909 135 C    HW: 7L0 909 135 C
   Component:    Kessy            6850
   Revision: 00H22071    Serial number: VWX3Z0H2826306
   Coding: 0000232
   Shop #: WSC 31414 790 00001
   VCID: 313F1C4A1D6C79C2E8D-8064
   Component: ELV                 XXXX
5 Faults Found:
00457 - Central Electronics Control Module / BCM (J519)
            013 - Check DTC Memory
             Freeze Frame:
                    Fault Status: 01101101
                    Fault Priority: 3
                    Fault Frequency: 0
                    Reset counter: 225
                    Time Indication: 0
                    Date: 2064.00.00
                    Time: 00:00:14
00186 - Control circuit; Relay for Supply Voltage Terminal 15SV
            006 - Short to Plus
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 8
                    Reset counter: 225
                    Time Indication: 0
                    Date: 2064.00.00
                    Time: 00:00:14
00576 - Terminal 15
            006 - Short to Plus
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 4
                    Reset counter: 10
                    Time Indication: 0
                    Date: 2064.00.00
                    Time: 00:00:14
01176 - Key
             Freeze Frame:
                    Fault Status: 01101000
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 255
                    Time Indication: 0
                    Date: 2064.00.00
                    Time: 00:00:14
            006 - Short to Plus
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 0
                    Reset counter: 10
                    Time Indication: 0
                    Date: 2064.00.00
                    Time: 00:00:14
Address 08: Auto HVAC
Cannot be reached
Address 09: Cent. Elect.
Cannot be reached
Unable to communicate with address 09. Are you sure the doors are unlocked?
Address 15: Airbags        Labels: 7L0-959-655.lbl
   Part No SW: 7L0 959 655     HW: 7L0 959 655
   Component: J234__3N VW8T       0250
   Revision: 92012025    Serial number: 0039P0076F5R
   Coding: 0013134
   VCID: 7AADFB66809A7A9A197-802E
   Subsystem 1 - Part No: 7L0 959 339 F
   Component: BF-Gewichtsens. 007 0010
   Subsystem 2 - Serial number: 3U8PP
   Subsystem 3 - Serial number: 0001.01.000000700000000000
   Subsystem 4 - Serial number: 000000
11 Faults Found:
00591 - Seat Belt Switch; Driver (E24)
            010 - Open or Short to Plus - MIL ON
             Freeze Frame:
                    Fault Status: 11101010
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 119782 km
                    Time Indication: 0
                    Date: 2024.05.21
                    Time: 00:50:34
01217 - Side Airbag Igniter; Driver Side (N199)
            001 - Upper Limit Exceeded - MIL ON
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 119782 km
                    Time Indication: 0
                    Date: 2024.05.21
                    Time: 00:50:34
01316 - ABS Control Module
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 58
                    Reset counter: 104
                    Mileage: 119782 km
                    Time Indication: 0
                    Date: 2024.05.21
                    Time: 00:50:34
00654 - Seat Belt Tensioner Igniter; Driver Side (N153)
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 119782 km
                    Time Indication: 0
                    Date: 2024.05.21
                    Time: 00:50:35
01211 - Belt Tensioner Igniter; Rear Driver Side (N196)
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 119782 km
                    Time Indication: 0
                    Date: 2024.05.21
                    Time: 00:50:35
01212 - Belt Tensioner Igniter; Rear Passenger Side (N197)
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 119782 km
                    Time Indication: 0
                    Date: 2024.05.21
                    Time: 00:50:35
01588 - Igniter for Head-Airbag; Drivers Side (N251)
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 119782 km
                    Time Indication: 0
                    Date: 2024.05.21
                    Time: 00:50:35
01589 - Igniter for Head-Airbag; Passenger Side (N252)
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 119782 km
                    Time Indication: 0
                    Date: 2024.05.21
                    Time: 00:50:35
01317 - Control Module in Instrument Cluster (J285)
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 144
                    Time Indication: 0
01312 - Powertrain Data Bus
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 3
                    Reset counter: 255
                    Time Indication: 0
01299 - Diagnostic Interface for Data Bus (J533)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 144
                    Time Indication: 0
Address 16: Steering wheel        Labels: 7L6-953-549.lbl
   Part No: 7L6 953 549 F
   Component: J527                3601
   Coding: 0010011
   VCID: 42DD4386A8CAF25A017-8016
No fault code found.
Address 17: Instruments        Labels: 7L6-920-xxx-7L6.lbl
   Part No SW: 7L6 920 990 P    HW: 7L6 920 990 P
   Component: J285 KOMBI-INST.    9733
   Revision: KHH06V42
   Coding: 0007201
   Shop #: WSC 22516 067 57207
   VCID: 46D55F9684A2CE7A2DF-8012
12 Faults Found:
00470 - Company Comfort Databus in Single Wire
            012 - Electrical Fault in Circuit
             Freeze Frame:
                    Fault Status: 01101100
                    Fault Priority: 2
                    Fault Frequency: 147
                    Reset counter: 102
                    Mileage: 109820 km
                    Time Indication: 0
                    Date: 2023.12.12
                    Time: 14:19:44
01303 - Telephone Transceiver (R36)
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 132
                    Mileage: 118476 km
                    Time Indication: 0
                    Date: 2024.04.27
                    Time: 04:52:48
01314 - Engine Control Module
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 144
                    Mileage: 119782 km
                    Time Indication: 0
                    Date: 2024.05.18
                    Time: 20:23:24
00778 - Steering Angle Sensor (G85)
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 12
                    Reset counter: 104
                    Mileage: 119782 km
                    Time Indication: 0
                    Date: 2024.05.21
                    Time: 00:34:25
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 12
                    Reset counter: 104
                    Mileage: 119782 km
                    Time Indication: 0
                    Date: 2024.05.21
                    Time: 00:34:25
01315 - Transmission Control Module
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 11
                    Reset counter: 104
                    Mileage: 119782 km
                    Time Indication: 0
                    Date: 2024.05.21
                    Time: 00:34:25
01324 - Control Module for All Wheel Drive (J492)
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 12
                    Reset counter: 104
                    Mileage: 119782 km
                    Time Indication: 0
                    Date: 2024.05.21
                    Time: 00:34:25
01771 - Control Module for Headlight Range (J431)
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 12
                    Reset counter: 104
                    Mileage: 119782 km
                    Time Indication: 0
                    Date: 2024.05.21
                    Time: 00:34:26
00562 - Sensor for Oil Level/Temperature (G266)
             Freeze Frame:
                    Fault Status: 01101010
                    Fault Priority: 2
                    Fault Frequency: 4
                    Reset counter: 104
                    Mileage: 119782 km
                    Time Indication: 0
                    Date: 2024.05.21
                    Time: 00:37:06
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 144
                    Mileage: 119782 km
                    Time Indication: 0
                    Date: 2024.05.22
                    Time: 00:05:04
00446 - Function Limitation due to Under-Voltage
            002 - Lower Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 144
                    Mileage: 119782 km
                    Time Indication: 0
                    Date: 2024.05.22
                    Time: 02:17:13
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 104
                    Mileage: 119782 km
                    Time Indication: 0
                    Date: 2024.05.24
                    Time: 03:36:48
Address 19: CAN Gateway        Labels:. 6N0-909-901-7L.clb
   Part No SW: 6N0 909 901     HW: 7L6 920 990 P
   Component: J533  GW-K-CAN TP20 9733
   Coding: 77E2F7DBCB846002
   VCID: 70B9D94ED6A630CAA73-8024
10 Faults Found:
             Freeze Frame:
                    Fault Priority: 2
                    Reset counter: 102
                    Mileage: 109820 km
                    Time Indication: 0
                    Date: 2023.12.12
                    Time: 14:19:44
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 132
                    Mileage: 118476 km
                    Time Indication: 0
                    Date: 2024.04.27
                    Time: 04:52:48
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 144
                    Mileage: 119782 km
                    Time Indication: 0
                    Date: 2024.05.18
                    Time: 20:23:24
02519 - Display Module for Roof (J702)
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 104
                    Mileage: 119782 km
                    Time Indication: 0
                    Date: 2024.05.21
                    Time: 00:00:05
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 12
                    Reset counter: 104
                    Mileage: 119782 km
                    Time Indication: 0
                    Date: 2024.05.21
                    Time: 00:34:25
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 12
                    Reset counter: 104
                    Mileage: 119782 km
                    Time Indication: 0
                    Date: 2024.05.21
                    Time: 00:34:25
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 11
                    Reset counter: 104
                    Mileage: 119782 km
                    Time Indication: 0
                    Date: 2024.05.21
                    Time: 00:34:25
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 12
                    Reset counter: 104
                    Mileage: 119782 km
                    Time Indication: 0
                    Date: 2024.05.21
                    Time: 00:34:25
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 12
                    Reset counter: 104
                    Mileage: 119782 km
                    Time Indication: 0
                    Date: 2024.05.21
                    Time: 00:34:26
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 144
                    Mileage: 119782 km
                    Time Indication: 0
                    Date: 2024.05.22
                    Time: 00:05:04
Address 22: AWD
Cannot be reached
Address 2E: Media Player 3
Cannot be reached
Address 37: Navigation (J0506)       Labels:. 1T0-035-680.clb
   Part No SW: 7L6 035 684 C    HW: 7L6 035 684 CX
   Component: RNS-MID       H66 1628
   Revision: AB001001    Serial number: VWZ6Z7R9334056
   Coding: 000100000100002600
   Shop #: WSC 49182 001 1048576
   VCID: 36352F56F8425EFABDF-8062
6 Faults Found:
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 2
                    Reset counter: 132
                    Mileage: 118476 km
                    Time Indication: 0
                    Date: 2024.04.27
                    Time: 05:01:42
00862 - Antenna for GPS Navigation (R50/R52)
            007 - Short to Ground - Intermittent
             Freeze Frame:
                    Fault Status: 00100111
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 144
                    Mileage: 115491 km
                    Time Indication: 0
                    Date: 2024.03.04
                    Time: 07:09:27
00532 - Supply Voltage B+
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 2
                    Reset counter: 144
                    Mileage: 119782 km
                    Time Indication: 0
                    Date: 2024.05.20
                    Time: 13:30:33
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 6
                    Reset counter: 144
                    Mileage: 119782 km
                    Time Indication: 0
                    Date: 2024.05.20
                    Time: 02:22:19
00821 - Antenna 2 for Radio (R93)
            011 - Open Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00101011
                    Fault Priority: 5
                    Reset counter: 143
                    Mileage: 109816 km
                    Time Indication: 0
                    Date: 2023.12.12
                    Time: 14:45:50
02635 - Tuner Not Enabled/Activated
            000 - -
             Freeze Frame:
                    Fault Priority: 7
                    Reset counter: 104
                    Mileage: 109816 km
                    Time Indication: 0
                    Date: 2023.12.12
                    Time: 14:45:56
Address 46: Central Conv.
Cannot be reached
Address 47: Sound System
Cannot be reached
Address 55: Headlight Range
Cannot be reached
Address 56: Radio (J0506)       Labels:. 1T0-035-680.clb
6 Faults Found:
             Freeze Frame:
                    Fault Priority: 5
                    Reset counter: 143
                    Mileage: 109816 km
                    Time Indication: 0
                    Date: 2023.12.12
                    Time: 14:45:50
            000 - -
             Freeze Frame:
                    Fault Priority: 7
                    Reset counter: 104
                    Mileage: 109816 km
                    Time Indication: 0
                    Date: 2023.12.12
                    Time: 14:45:56
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 2
                    Reset counter: 132
                    Mileage: 118476 km
                    Time Indication: 0
                    Date: 2024.04.27
                    Time: 05:01:42
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 144
                    Mileage: 115491 km
                    Time Indication: 0
                    Date: 2024.03.04
                    Time: 07:09:27
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 2
                    Reset counter: 144
                    Mileage: 119782 km
                    Time Indication: 0
                    Date: 2024.05.20
                    Time: 13:30:33
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 6
                    Reset counter: 144
                    Mileage: 119782 km
                    Time Indication: 0
                    Date: 2024.05.20
                    Time: 02:22:19
Address 65: Tire Pressure        Labels:. 7L6-907-273.lbl
   Part No SW: 7L6 907 273 E    HW: 7L6 907 273 E
   Component: J0502 RDK           0006
   Revision: 00004006    Serial number: 00000600012534
   Coding: 0040007B7B0000000000000000
   VCID: 3A2D3B66C01ABA9A597-806E
1 Fault Found:
01840 - Antennas for Tire Pressure Monitoring
            005 - No or Incorrect Basic Setting / Adaptation - Intermittent - MIL ON
             Freeze Frame:
                    Fault Status: 10100101
                    Fault Priority: 3
                    Fault Frequency: 3
                    Reset counter: 144
                    Time Indication: 0
             Freeze Frame:
                    (no units): 177.0
Address 68: Wiper Electr.        Labels: 7L0-955-119-V2.clb
   Part No: 7L6 955 119 B
   Component: J400__ Front Wiper  5301
   Coding: 0001397
   VCID: 392F246AC55CB18250D-806C
   Subsystem 2 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS     170209 054  0402
   Coding: 00208941
   Shop #: WSC 31414
Address 69: Trailer
Cannot be reached
Address 6C: Back-up Cam.
Cannot be reached
Address 6D: Trunk Elect.        Labels: 7L6-959-107.clb
   Part No SW: 7L5 959 107     HW: 7L5 959 107
   Component: J605  HECKKLAPPE    0101
   Revision: --002---    Serial number: --------002234
   Coding: 2121210
   Shop #: WSC 128452 000 00000
   VCID: 77ABE252B38867F2669-8022
4 Faults Found:
01543 - Parking Aid Warning Chime (H15)
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01101011
                    Fault Priority: 3
                    Fault Frequency: 14
                    Reset counter: 177
                    Time Indication: 0
                    Date: 2021.07.08
                    Time: 12:59:58
03234 - Functionality Limited due to Critical Electrical Condition
            000 - - - Intermittent
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 55
                    Reset counter: 144
                    Time Indication: 0
                    Date: 2024.05.19
                    Time: 23:07:13
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 144
                    Time Indication: 0
                    Date: 2024.05.21
                    Time: 12:22:35
01336 - Company Data Bus for Comfort System
             Freeze Frame:
                    Fault Priority: 3
                    Reset counter: 144
                    Mileage: 0 km
                    Time Indication: 0
Address 6E: Ctrl Head Roof
Cannot be reached
Address 76: Park Assist        Labels: Redir Fail!
   Part No: 7L0 919 283 F
   Component: 0E Einparkhilfe     1107
   Shop #: WSC 00000 000 00000
   VCID: 392F246AC51CB18250D-806C
Address 77: Telephone        Labels: 5P0-862-335.lbl
   Part No SW: 1Z0 035 729 A    HW: 1Z0 035 729 A
   Component: FSE_2P8x        H34 0150
   Revision: 00000000    Serial number: 00000005016650
   Coding: 0012077
   VCID: 36352F56F4425EFABDF-8062
2 Faults Found:
             Freeze Frame:
                    Fault Priority: 7
                    Fault Frequency: 1
                    Reset counter: 144
                    Mileage: 119782 km
                    Time Indication: 0
                    Date: 2024.05.21
                    Time: 12:21:49
             Freeze Frame:
                    Fault Priority: 7
                    Fault Frequency: 1
                    Reset counter: 144
                    Time Indication: 15
End----(Elapsed Time: 04:13, VBatt start/end: 12.4V/12.2V. VIgn 0.0V)------
here is the auto scan :) also, i put a picture of what fuse i jumped to get the cluster lit up
