1 - 7 of 7 Posts
CristiGeo
Discussion starter · #1 ·
Hi,
Could someone please provide me with the pinout of the ignition switch for a 2008 3.0 TDI CASA engine code from ELSA or anywhere else?
Looking forward for a picture or something..
Thank you
In theory there isn't an actual ignition switch, per se. The entire process is handled by module 05-Access/Start Authorization. When you turn the key, the "ignition switch" sends a signal to the 05 module asking if it's OK to turn on the ignition or start the engine.
I can get you a pinout in a bit. What are you trying to accomplish?
If you want to install a keyless engine start/stop button, you can very easily retrofit the factory button. You basically need the button and wiring harness. Then drill a hole in the shifter trim, install the buttons, and wire up the button to the 05 module under the dash. The link explains it all.
1 - 7 of 7 Posts
