Newest problem for me is not being able to remove the key. Currently with the key in the park position and the key on I can't shift the gear selector w/o depressing the brake pedal. However turn the key off and I can shift to every position. Right now the shifter lock button is locked in and when in park it doesn't pop out or allow me to remove the key. What next ?? DIY perfered.
What year is your Treg since you don't have it listed anywhere?
Original battery in that? If so low voltage to from the battery causes weird things to happen.
Thanks for the reply. Got curious this morning and removed the shifter handle. Appears that the internal sliding mech. that engages the lock button is in need of lubrication. Will try that and see what happens. As soon as I removed the shifter handle it locked right in place and I could remove the key. ????
