I need help !
2.1K views 26 replies 6 participants last post by  volkswagens-for-life
Has anyone ever removed that pipe from the turbo manifold to the egr cooler on the back of the drivers side cylinder head of a 3.0 tdi ? Mine is leaking in the accordion part, but I cannot get to one bottom bolt on the manifold side. Any tips ? I am about ready to just sell this mf'er and buy and Armada.
The circle is where the crack is.
I thought you deleted?
I was going to delete this pipe, and eventually the egr. But I can't get this stupid pipe out. I'm not proud of it.... but I tried some exhaust repair wrap on the cracked area. Did not work, shocking I know lol. I think I can use my little air saw and cut that pipe close to turbo and then I would be able to get the bottom bolt out.
Do you already have the block off plates and coolant rerouting kit on hand?
No coolant bypass kits available for the cata. I was going to use the flanges of that pipe to make block offs.
They made the bypass kit for the CATA before any of the other engines
One more issue I discovered today....
There is a slight bit a black soot visible on the turbo housing around the vane actuator shaft. Is any amount normal or is it new turbo time ?
How the heck would soot get on the actuator shaft?! What is leaking for that to occur
Reactions: KDSAjp
Excellent choice, they are wonderful SUVs I think you'll love it
Reactions: KDSAjp
Shoot I haven't been in the CATA game for a few years now but I thought dark side dead and I know there's a couple other companies floating around on this very website doing it
Just FYI FunBard... the best stuck bolt or nut penetrant is a 50/50 mix of ATF & Acetone !! You should know that the Acetone evaporates fairly fast so if you make any amount and put it in say an oil can and expect it to last for a few weeks, it won't.. so buy the smallest amount of Acetone to make your mixture. BTW.. you can fast forward through this video.. LOL
I @ his ass for input lol, waiting for him to get back to us @sustdi where the **** are you, take a break from Christmas dinner for Christ's sake
  • Haha
Reactions: C-ya
@sustdi I'll just @ you until I die
