Yup, the can of gunk and a compressor is all you need according to VW unless you had the foresight to spec the spare wheel in the options list for a hundred dollars or so.
I needed it to install my mud flaps, anyhow I ended up buying one from my local auto store. And yes they do give you a wheel lock tool. Another thing I discovered is that my hydraulic jack does not raise high enough to lift the wheel off the ground. I ended up using 2'x6' under the jack to give it enough height.Really no need to take the wheel off if you don't have a spare to put on. My guess is the can of fix a flat is supposed to get you to a garage or tire shop with the proper tools to take the wheel off. Brake jobs on those won't exactly be a DIY type deal given the nature of the brakes helping to recharge the battery. Something else to think about, did the give you the wheel lock tool or does the Hybrids not have wheel locks on them from the factory?
No such symptoms on mine. One thing I noticed is on overnight/cold starts I hear a rattling noise for about 1-2 secs coming from the engine, VW tech tells me it's the timing chain cams filling with oil. Does yours make the same noise? Here is the sound clip:Good to see more Hybrid folks in the forums.
I own an '11 and posted some concerns a while back. Thought it might make sense to get some feedback on this thread.
My biggest issue is the occasional rough disengagement of the electric/gas clutch. When it happens, I'm coming to a complete stop and the stop feature clunks to shut down the gas engine. Not so much of an audible clunk, but rather a feeling in the drivetrain.
I also think that the car starts rough. Seems to jar the whole car when starting. Is it possible that the electric motor starting the gas engine is torquey...more than a traditional starter.
Anyone else have symptoms similar to these?
Even if you have standard jack, a decent timber pad in the boot / trunk comes in handy if the ground is soft [and it's not quite to far to have to wind the jack up either!]. Mine has a "seat" that the jack foot sits in to locate it.I needed it to install my mud flaps, anyhow I ended up buying one from my local auto store. And yes they do give you a wheel lock tool. Another thing I discovered is that my hydraulic jack does not raise high enough to lift the wheel off the ground. I ended up using 2'x6' under the jack to give it enough height.
Can't say I hear that at start up, but to be frank, I've never had the hood open at start up. Does it sound similar, although muffled with the hood down?No such symptoms on mine. One thing I noticed is on overnight/cold starts I hear a rattling noise for about 1-2 secs coming from the engine, VW tech tells me it's the timing chain cams filling with oil. Does yours make the same noise? Here is the sound clip: https://www.youtube.com/watch?v=V5tp8Q7MTNU&feature=g-upl
Never mind the name of the clip, I did so that I could have an S4 community to chime in without asking too many questions.
I did take it to the dealer,they kept it overnight and said the sound is normal coming from chain tensioner cams filling with oilIf my engine sounded like that Audi at startup I'd be a little concerned. It almost sounds like something external to the engine, not internal. I had a 1975 Toyota Celica that made a similar noise, only at a fast idle. Turned out it was a butterfly valve on the air intake resonating against the air filter housing.
Darn, you just added another mod to my list, lol.No headlight washers for US T3 models.
Do it! do it! The only downside of the hybrid is looking foolish with that smile you can't wipe off your faceThere's a great deal on a hybrid in western NY..thinking of buying...hmm.
Sigh...you know me too wellAs far as e-mode, don't kid yourself you're not buying this car for an e-mode, you're buying for its 380hp/428tq with a gas consumption of a Camry.
