How to replace your stock Touareg BATTERY
373K views 195 replies 86 participants last post by  New2Tregs
No, Goeff did not send you a 10mm Triple square bit. I believe they were 5 and 16 that were included in the brake kit. You will need to buy one in order to remove the seat bolts.
siberian said:
I don't worry about the dust more peeling my butt off the ice... :)
As my battery is due for replacement soon, I was groping around trying to find the bolts at the edge of the rail cover but didn't find anything so I was wondering if they're behind that vertical cover in front of the seat. Also whether the rail covers simply snap off or slide off.
siberian
The bolts are actually if memory services me right at the base of that piece in front of the seat on the floor.
Why did you need to move your seat? You can access the two bolts that allow they whole thing to hinge back with out moving it. Did you remove it from the tracks?
