1 - 4 of 4 Posts
Hi,
I’m trying to get the fuse board on the LHS. It’s RH drive so I need to remove the glove box.
I rolled the user manual and was able to remove the pin which connects to the soft open mechanism however, I am stumped on how to remove the glove box itself.
Has any one managed to do it? I’m trying to tap into some PWR and ACC fuses for my dash cam.
Any assistance would be greatly appreciated.
I think you'll find the fuse panel is behind a removeable cover on the left side of the front passenger footwell so no need to remove the glovebox other than to maybe run the wires. Use a plastic (or non metal tool) to prize off the cover. The covers at either end of the front instrument panel can be removed in a similar manner if required, which may help in running the wires. There's also a fuse panel under the drivers' instrument panel, which can be removed by undoing 3 screws along the edge, and then pulling down to unclip it, then pulling aft to disengage it from a holder near the steering column! Sounds more difficult than it actually is.
Learner
agree, dont have to remove the glove box to get to the fuses on the side.
1 - 4 of 4 Posts
