1 - 7 of 7 Posts
2011 VR6 FSI LUX
Search Results for ‘Hi guys my 2007 touareg does not charge phones via 12v sockets if key is off how do I change this or is there a 12v socket I can use without switching on my car’
At the risk of draining down the battery by accident, you could run your own wired 12v lighter socket to a constant 12v point in the fuse box and place the socket in a convenient spot.
just use a little “juice box” which is made for charging smartphones anywhere. The one I have has worked great for years already for charging smartphone and tablet when I was away from electricity.
2014 VR6 Exec
2011 VR6 FSI LUX
To add to this, you can also get the following or something similar, which cuts off power if the battery gets too low. I use it as a safety for my constant-on dashcam.
That's a great alternative. I like that it has power cutoff to prevent too much battery drain.
Reactions: gryhnd
Discussion Starter · #7 ·
post: 2158183, member: 222069"]
Here are some self-explanatory photos. Although mine is a T3, yours will be similar. Look for the fuse at right hand side of car. Redirect the 12v IN to one that is Fulltime 12v OUT.
View attachment 253330 View attachment 253331 View attachment 253332
[/QUOTE]
At the risk of draining down the battery by accident, you could run your own wired 12v lighter socket to a constant 12v point . the fuse box and place the socket in a convenient spot.
ok thanks thought there was a fuse or something simple I needed to change
1 - 7 of 7 Posts
