So I had to replace a bulb in the RHS light this weekend and read all the warnings and tried VERY carefully to remove the light. I wiggled it a bit, sprayed some WD40, put pressure on etc, etc. In the end I got the light out without breaking anything but then saw how dirty it was underneath the light, so I took the LHS one out as well for cleaning.
After cleaning both lights and trays, and replacing the bulb, I put the lights back in and guess what... I broke the TOOL putting the RHS one back in!!! :anger: It split open at the hole where the allen key goes through. I cut the end off, drilled a new hole and refitted the allen key, so now my tool is about 1/2" shorter.
Anyways, I think next time I'd rather use a small socket and ratchet than the VW tool.
I think the trick to not breaking the mechanism is to make sure you do NOT put any bending (sideways) force on the lock when turning. Make sure you ONLY apply a torque, if that makes any sense... The SLIGHTEST little bit of bending (forwards, backwards, left or right) will break the mechanism as in the pic above.
BTW, while the lights were out, I fiddled with the adjusting screws. Dunno how I'm supposed to adjust these lights when they're in the car, as THESE mechanisms are also VERY flimsy an look like they'll also split open the moment you try adjusting. Luckily my aim is OK, so I don't need to adjust them.
