Castrated Fatman!
Most people in these circumstances get a pair of mole grips, grip very firmly what they can of the locking bar [sometimes having to use a small dremel to cut an access point] and twist firmly in the UNDO direction and, hey presto, the headlight unit moves forward as it should.
I take it you know there is then a hard-to-find-but-dead-easy-once-you-know-where-it-is détente spring you have to push down to release the unit in its entirety?
You can replace the headlight buckets the light units sit in, but to do so you have to remove the front bumper which is easy enough, but a two man job as it is bulky.
Do make sure you buy a pair of genuine [always replace bulbs in pairs] Osram or Philips bulbs, not some ***** copy off fleabay.
