The terrain tech models have a high/low range transfer case.The eight speed does indeed have a transfer case! Yes, it is a Torsen based single speed, as opposed to the older two speed Haldex based unit, but without a transfer case, how do you think the power gets to the front wheels?
Odd, it showed up under recent threads.Four year old thread here Chew!
Can somebody read my question again and reply to that?Does anyone knows if the 8-speed and 6-speed gearbox houses have the same interference flanges? To engine and transfer case?
Software is not the issue here from mine side.
I am willing to make the swap on a V10 TDI engine.
TR80SD can handle 850Nm, info found in spare part catalogue no issue here I think.Can somebody read my question again and reply to that?
Again software adaptation is no issue here, thanks.
