41 - 55 of 55 Posts
2007 Volkswagen Touareg
Most of those points are pretty fair.
HIDs have come a very very long way though. That's the bare minimum I would have in a car, with a good set of LEDs being optimal.
Fair enough. Halogens are very old tech. HIDs are a vast improvement in brightness. And I agree that LEDs are preferred. However, I'm finding upgrades from HID to LED to be a bit cumbersome and finding a reliable D1S LED that will work (especially without canbus errors) is a bit of a crapshoot. It seems like you run into less compatibility issues when going from Halogen to LED. Does that make sense?
2008 V6
The "problem" is the lens degrade over time and the cost of generic halogen replacements vs. new genuine VW hid units will only get worse over time. Spending 1200 on headlights for a 5k truck is not very attractive.
Totally makes sense... I hear you.
I was about to suggest diode dynamics but they don't have anything. I hear you on wanting to convert but it's truly going to suck ass. Probably easier to buy OEM housings and some nice Phillips HID bulbs
You may have only paid $5,000 for it but it was a $70,000 truck. So now that you understand the situation properly, $1,200 headlights on a $70,000 car aren't so bad. They are $5,000 a piece for Audi matrix LED replacement housings, don't complain.
I have been looking into replacing both assemblies with brand new OE. I have the T1 1st-Gen HIDs with static directionals (PNs 7L6941017BQ & 7L6941018BQ) which were used in North America (not sure of other locations) for 2006 and early 2007 only, after which VW released a minor facelift to the front ends. So here we are, sixteen years later, and these two headlight assembly models are all but impossible to find, even used. That is what has led me to consider retro-modding to the halogen models. At least if I go halogen, I can upgrade to some respectable LED lamps for a fair improvement. I fear my poor Treg might be a driveway ornament for some time while I search for the best option.
· Super Moderator
You can still used LED lamps in the existing HID housing. No need to down grade to Halogens, to then upgrade again. Much easier transition.
****... Great insight. I can appreciate your efforts and motive behind this. Unfortunately I don't have much that I can offer at this point other than suggesting check out car-part.com which I've had lots of success using
· Super Moderator
When I replaced my Headlights with New HID's, the whole assembly. I got them on amazon.
2008 V6
I think it's more the wiring on these.
Wiring is fine on our 2008. But after multiple "polishes" the plastic lenses are hopeless. If they sold those separately, a big problem would be solved. The fact is even if the wiring or reflectors or ballast lasted forever, the original lenses on most T2 headlights are now worthless. No amount of polishing, or "new bulbs" or re-wiring or reflector repair matters much once the lenses are gone. That's why plugging a pair of cheap new aftermarket halogens every two or three years would be the sane solution to keeping a 15 year old truck (dwindling in value) on the highway. We're adding some LED driving lights for now...
· Super Moderator
You're not polishing right. I can make any headlight look brand new. I can walk you though the correct process if you want.
Here are some examples of my car's that I've done.
Automotive side-view mirror Vehicle Car Automotive parking light Grille
Grille Automotive tire Hood Automotive lighting Tire
Automotive parking light Vehicle Grille Automotive lighting Automotive tire
Automotive parking light Car Vehicle Grille Automotive lighting
Automotive parking light Automotive tail & brake light Automotive lighting Vehicle Motor vehicle
Automotive parking light Automotive tail & brake light Automotive lighting Automotive tire Motor vehicle
Automotive parking light Grille Automotive tail & brake light Vehicle Automotive lighting
Automotive parking light Automotive side marker light Land vehicle Vehicle Grille
Automotive parking light Land vehicle Vehicle Automotive tail & brake light Grille
Automotive parking light Grille Automotive lighting Hood Automotive tire
Touaregman, THIS would be my ultimate solution! If you have experience with such, or know of any threads that might help, I would greatly appreciate it! My biggest concern is getting error codes from the LED installs. I have heard too many mixed messages regarding this. I also have no idea which brand(s) of LEDs to trust. I have researched three that I think might be worth a try, but from my limited experience, this would be little more than a big, fat experiment. Hopefully, I wouldn't fry a ballast or controller! (UGH)
· Super Moderator
Not a Touareg but may help
41 - 55 of 55 Posts
