Ive searched for quite some time and cannot seem to find the right answer. I have a good quality Morimoto 35 watt 3000 kelvin hid kit that i bought a while ago, and I'm considering on installing it on my 2008 touareg in the fog lights. Now my question is, upon installing the kit has anyone had error messages come up on the dash? Does the green "bulb out" light come on? If so, what is the solution you (if any) did you come up with? I did find a couple threads where people say they used the canbus adapters but they still had problems with the lights not coming on all the time and flickering at times.
So my question is would a relay help solve that problem? So instead of connecting from the vehicles fog connector to the ballast and to the bulbs, connect from the fog connector to the relay, then a positive from the battery to the relay and from the relay to the ballast and bulb. So the headlight switch would only trigger the relay, and the lights would be powered straight from the battery. Hopefully i described in a way that is understandable. Or would this cause more problems and not solve anything?
Thoughts?
Thoughts?
