1 - 4 of 24 Posts
Have had crazy issues with headlights. So both were flickering for a while. Finally i broke down and bought two new bulbs. Replaced them both which was an adventure considering the previous owner broke the heads off the release. Both bulbs back in and working fine for a day then out of the bleu i start the treg and the warning light came on. I got out and checked lights and sure enough the drivers side was out. Tried restarting treg and turning lights on and off. No luck. Tried a new bulb yet still wont turn on. I have no leveling or flapper nor bi xenon on drivers side. Checked wiring all looks good. Swapped ballasts thats where im confused. Pass side ballast still will not operate drivers side assembly and drivers ballast wont operate pass side assembly. Should the good ballast not make the drivers side work drivers side still has signal and marker lamp and high beam still work. Looking for some advice or a diagram of which pins are what on the vehicle side where the assembly plugs to.
Had some time. Checked all the fuses drivers side and pass side. Even that bank of fuses under hood by the windshield on drivers side. All fuses are good. Ill try removing that harness that plugs into back of light and ensuring proper contact. Though i did push in on it while headlight was in several times. Is it possible if passenger side harness is not in all the way this could affect drivers side? Appreciating all the help. I also have a bank 1 too lean and bank 2 too lean fuel catalyst below threshold. I have had bank 1 on for a long time now but bank 2 showed up after both fuel pumps stopped working. I have bought some O2 spacers for rear sensors but have yet to put them on. Someone suggested this may resolve that issue or at least mask it. What a nightmare. I love my treg but its
Becoming time consuming.
1 - 4 of 24 Posts
