My 2015 Execline TDI has an irritating random short buzzing sound (sounds like saying "BZIT") that comes from the rear of the center console (near the 110 outlet). It occurs randomly, but not infrequently. Typically about 10-15 minute into any drive it will buzz two to four times in quick succession, and then again randomly (at anywhere from 5 to 30 minute intervals) with anything from a single to a multiple "BZIT". It is quite audible when the radio is not on. I accidentally discovered that the sound can be triggered by leaving the vehicle parked but running and moving the key outside of, and away from the car (via a second person).
The dealer investigated and declared on the invoice: "NOISE COMING FROM KEYLESS ANTENNA IN CENTER CONSOLE. REPLACE ANTENNA, NOISE NOW GONE"
Only they verbally told me they just wrapped the antenna in a sound deadening foam and it was "much better". When I said I didn't think the sound was normal, they told me it was, and that all the "Keyless one-button start" models make that sound and that the car needs to confirm they key is always in range—which makes some sense, but doesn't explain the noise. Since my previous Touareg didn't have they keyless start, I can't say if it is "normal".
I suspect I'm being given a typical BS explanation, but before I push it, can anyone else tell me if they have experienced this noise as well? Supposedly ALL of you (except anyone who is very hard of hearing) with keyless start will have heard this sound while driving, although I doubt many have had someone take the key away while the car is parked but running.
Any help and suggestions gratefully appreciated!
Mark
Mark
