1 - 4 of 4 Posts
Hi, i want to change my old rear view mirror with auto dim one. I buy used but there are 6 cables, can you tell me which ones i need to use. The colors are:
1 Brown- (that is ground i think)
2 Brown/green
3 red/green
4 red/yellow
5 black/green
6 black/blue
Be aware that the auto dimming mirror takes some time to dim and does not always dim when you want it to. And there is no way to FORCE it to dim other than covering up the front sensor.
Honestly, I sometimes wish I had the manual one. It's not that hard to flip a lever.
Now when i connect brown to ground and red/green to 12 v the green light on the mirror is on but no dimming even if i cover the rear sensor and flash the front. Also when i connect possitive to blue/green then it is always dimmed and the button also cant switch it off.
1 - 4 of 4 Posts
