1 - 3 of 3 Posts
2004 3.2l V6 Touareg
Does anyone know the name of L-Shaped pipe with the green paint on it? i need to replace it due to it leaking.
Not sure because of the connector, but the pipe and the shielding on it looks like that of a PCV pipe. If it goes from the valve cover into the intake pipe and leaks oil, then that's what it will be. But I'm confused by the title. Or do you think this is a vacuum pipe? There should be some part number on it though.
1 - 3 of 3 Posts
