I recently took the Treg to an indy to have the transmission fluid changed (I'm at 130k miles). When he was done he gave me back 2 of the fluid containers from the flush kit.
I was concerned that he didnt put enough in so today I raised the air suspension to the max and went under to check the level. The tray was warm but not hot. When I removed the fill plug from the bottom, about a quart of fluid dumped out onto the ground.
I have no idea why this happened, the truck was level. Was I supposed to do this with the engine cold? How do I know if I have enough fluid in there to start the truck again
