Hi,
About 6 weeks ago I bought a second hand Treg 2004 2.5 TDI PD and after a couple of weeks a message saying "Insufficient Coolant" came on. I researched this a bit on the forums and eventually topped up with water as the liquid in the tank appeared clear and I didn't want to put in G12 after what I had read. It took approximately 1 litre of water before the level was on the Min mark. It has since done this twice more and I would say I have put 4-4 litres of water in in total.
I am no mechanic but this weekend I decided to have a look to see what I could see!!
Firstly - when the engine is turned on there is a hissing noise coming from it and what appears to be exhaust gas coming from (what I think) is the exhaust side of the engine. I cant see exactly where. The gas does not pour out but can be seen if watching carefully.
There is also a lot of dried liquid as can be seen in the picture. When I turned the engine on for the first time there was also liquid coming from what I think is the pipe that takes exhaust gases to the Exhaust Gas Recirculation unit near a joint in the pipe. This only happened the first time although I did only look for about 15 minutes and I don't think the engine ever really got hot.
Anyway - to cut a long story short I have it booked in at the dealers next week but just wanted to give myself an idea on what I was in for and wondered if anybody could help.
I am also not 100% sure if all the "bits" are in the right place as I think some hoses may be slightly out of place and one in particular is quite worn from rubbing on the engine cover.
In addition - I have also noticed liquid on the floor under the passenger (left) side of the car slightly being the front wheel. I have collected some of this liquid which is very clear in colour but only seems to leek when the Air-Con is switched on.
I have attached a couple of pictures to give an indication of the situation and also pose a couple of simple questions.
