Could you please help me identify the issue?
I have a leak, it doesn't seem to be the sills filling with water, I think it might be coolant as I'm loosing coolant slowly and have also had a red coolant error light and needed to refill. I travelled a good distance and the same happened again.
Video is from my arm shoved inside the passenger side engine space near the left wheel looking toward the back of the car at the bulkhead. The bulkhead is a near vertical section slightly towards the middle of the bulkhead. You can see the exhaust heat shield passing between the body and gearbox to the left, and there is a plastic or rubber piece that looks somewhat like a T piece pull handle with a surround.
Apologies for the limited quality of the video, it was a nightmare to see at all let alone with a camera and light.
Sent from my iPad using Tapatalk
