1 - 14 of 14 Posts
Hello Club Touareg. Thanks for letting me join. I just purchased my first Touareg, a 2009 TDI. It was a fresh trade in that I got for cheap because it has some issues that I'm now trying to resolve.
Here's what I know happened before I purchased it. The car had been sitting and the battery was dead for a while. A VW dealer put in a new battery and their scan afterwards indicated there was no communication to the comfort module. I don't have any paperwork on this, this is just what I was told when I bought the car.
I ordered a VCDS cable so I'm just manually troubleshooting while that comes in. Here are the issues I'm seeing now that I have the car. The keyfob, tailgate, rear window, rear wipers and a few other bits are not working. I'm able to open the tailgate and rear window using the emergency release from inside. My research online points to a faulty ccm module. The rear lights do work fine however. I've tried a used ccm from a 2008 (7L6 959 993 vs my 7L6 959 993 A) and I get the same results. I did a quick visual look at the wires coming in at the tailgate hinges and they all look fine. I didn't remove the protective jacket around them however. I've traced the wires from most of the components in the rear lid and they all have continuity to the CCM 23-pin connector. Also, all fuses appear to be ok. It's possible that both ccm modules are faulty in the same way.
Other issue is that I have an AdBlue warning with 450km left before I can't start the car anymore. I don't know if that can be related to my other electrical issues, but I do know that VW will refill and fix that for me for free, but I'm waiting to fix this other issue or else I know they'll most likely charge me a diagnostics fee.
Oh, one thing I should mention is that I verified that the tailgate microswitch is working properly using a multimeter, and while I was troubleshooting all this I noticed that if I manually push in the latch mechanism in 1 step, the tailgate handle will work. If I push it in twice, the lower locking mechanism will engage and then it won't work at all. I have to use the emergency release to open the latch. At this point, the lower mechanism is still in the lock position. If I manually click int he latch 1 step, the tailgate handle will open the latch and also unlock the locking mechanism. I hope that made sense.
Thanks in advance for the help!
Try to test all doors including tailgate switch and all lights with vcds when you get it.
Do an auto scan an upload it here.
Part number 7L6959933 was replaced by 7L6959933A in 2008. So you probably got a faulty used part. You should look for the same part number 7L6959933A.
Let's wait for the vcds scan with the original module before you order another one.
I really look forward to my VCDS cable to come in so I can scan it.
I did a bit more troubleshooting this weekend. All wires at the hinges appear to be intact. The tailgate does not open when fully locked/latched however If I open the rear window by pulling on the manual release, the tailgate will open when fully locked/latched. Using a multimeter I can see that both the rear window and the tailgate locks will have a closed cuircuit unless it's fully locked. So when one or the other is not fully locked, the tailgate will function properly.
Finally got my VCDS cable and did an auto-scan. I've got faults everywhere, so I suspect I have a cut wiring harness or a missing ground?
Code:
Tuesday,02,June,2020,15:17:27:21308
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 20.4.1.0 (x64)  HEX-V2 CB: 0.4508.4
Data version: 20200331 DS317.0
www.Ross-Tech.com
VIN: WVGDM67L69D035443   License Plate:
Mileage: 188370km-117047mi   Repair Order:
Chassis Type: 7L (6N0)
Scan: 01 02 03 05 08 09 0F 15 16 17 19 1C 22 36 37 46 47 55 56 68
          69 6D 6E 76
VIN: WVGDM67L69D035443   Mileage: 188370km-117047miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
0F-Digital Radio -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
1C-Position Sensing -- Status: Malfunction 0010
22-AWD -- Status: OK 0000
36-Seat Mem. Drvr -- Status: Malfunction 0010
37-Navigation -- Status: Cannot be reached 1100
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Cannot be reached 1100
47-Sound System -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: Malfunction 0010
68-Wiper Electr. -- Status: OK 0000
69-Trailer -- Status: Cannot be reached 1100
6D-Trunk Elect. -- Status: Cannot be reached 1100
6E-Ctrl Head Roof -- Status: Malfunction 0010
72-Door, Rear Right -- Status: Cannot be reached 1100
76-Park Assist -- Status: Malfunction 0010
Address 01: Engine (CAT)       Labels:. 059-907-401-CAT1.clb
   Part No SW: 7L0 907 401 T    HW: 7L0 907 401 K
   Component: 3.0TDI FSA  G004AG  0140
   Revision: 33H01---    Serial number: VWX3Z0H2826371
   Coding: 0421002A590F0968
   Shop #: WSC 64857 003 1048576
   VCID: 3C2131BDAA7E942B4F3-5184
No fault code found.
Readiness: 0 0 0 0 1
Address 02: Auto Trans        Labels: 09D-927-750.clb
   Part No SW: 09D 927 750 HN    HW: 09D 927 750 HN
   Component: AL 750 6A           3403
   Revision: 00H75000    Serial number:
   Coding: 0004984
   VCID: 015F80498D1C39C35C5-5184
Address 03: ABS Brakes        Labels: 7L0-907-379-MK25E1.clb
   Part No SW: 7L0 907 379 P    HW: 7L0 614 517 C
   Component: ESP ALLRAD MK25E1   0304
   Revision: 00H53001
   Coding: 0004354
   Shop #: WSC 31414 790 00001
   VCID: 46D55355E4E2DEFB297-8012
2 Faults Found:
02781 - ASR/ESP Button (E256)
            008 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 2
                    Fault Frequency: 9
                    Reset counter: 152
                    Mileage: 188251 km
                    Time Indication: 0
                    Date: 2019.03.12
                    Time: 01:49:57
             Freeze Frame:
                    Count: 0
                    Count: 12289
                    Count: 156
                    Count: 1
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
            000 - -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 2
                    Fault Frequency: 22
                    Reset counter: 154
                    Mileage: 188374 km
                    Time Indication: 0
                    Date: 2019.03.13
                    Time: 00:00:46
             Freeze Frame:
                    Count: 128
                    Count: 4353
                    Count: 294
                    Count: 1
Address 05: Acc/Start Auth.        Labels: None
   Part No SW: 7L0 909 135 C    HW: 7L0 909 135 C
   Component:    Kessy            6850
   Revision: 00H22071    Serial number: VWX3Z0H2826371
   Coding: 0000232
   VCID: 313F10897D6C6943EC5-8064
   Component: ELV                 XXXX
4 Faults Found:
01330 - Central Control Module for Central Convenience (J393)
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 6
                    Fault Frequency: 14
                    Reset counter: 112
                    Time Indication: 0
                    Date: 2064.00.00
                    Time: 00:00:14
01334 - Door Control Module; Rear Right (J389)
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 14
                    Reset counter: 112
                    Time Indication: 0
                    Date: 2064.00.00
                    Time: 00:00:14
00185 - Control Circuit; Relay for Supply Voltage Terminal 15
            009 - Open or Short to Ground - Intermittent
             Freeze Frame:
                    Fault Status: 00101001
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 149
                    Time Indication: 0
                    Date: 2064.00.00
                    Time: 00:00:14
01341 - Control Module in Instrument Panel On Comfort CAN (J285)
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 6
                    Fault Frequency: 0
                    Reset counter: 149
                    Time Indication: 0
                    Date: 2064.00.00
                    Time: 00:00:14
Address 08: Auto HVAC        Labels: 7L6-907-040.clb
   Part No: 7L6 907 040 AK
   Component: CLIMAtronic R/L     4337
   Coding: 0003030
   VCID: 79AFE8A9E59C6103145-802C
1 Fault Found:
Address 09: Cent. Elect.        Labels:. 7Lx-937-049-V2.clb
   Part No SW: 7L6 937 049 AF    HW: 7L6 937 049 AF
   Component: J519                2004
   Revision: -0004---    Serial number: --------------
   Coding: 230008002F00BC000000000000000000
   VCID: 0059854D864630CB53B-8054
7 Faults Found:
01517 - Control Module for Trailer/Towing Sensor (J345)
00908 - Control Module for Wiper Motor
02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
00061 - Footwell Lights
            007 - Short to Ground - Intermittent
Address 0F: Digital Radio        Labels: 8E0-035-593-SIR.lbl
   Part No SW: 8E0 035 593 M    HW: 8E0 035 593 M
   Component: SDAR SIRIUS     H07 0150
   Revision: 00000000    Serial number: AUZ4Z7I0515179
   Coding: 0000102
   VCID: 33331A8187305B539E9-8066
1 Fault Found:
02635 - Tuner Not Enabled/Activated
            000 - -
             Freeze Frame:
                    Fault Priority: 7
                    Fault Frequency: 1
                    Reset counter: 152
                    Mileage: 188214 km
                    Time Indication: 0
                    Date: 2019.03.04
                    Time: 20:19:49
Address 15: Airbags        Labels: 7L0-959-655.lbl
   Part No SW: 7L0 959 655     HW: 7L0 959 655
   Component: J234__3V VW8T       0250
   Revision: 92012025    Serial number: 0039P0075208
   Coding: 0013142
   VCID: 7AADF7A5E09A6A1B1DF-802E
Address 16: Steering wheel        Labels: 7L6-953-549.lbl
   Part No: 7L6 953 549 G
   Component: J527                3601
   Coding: 0010211
   VCID: 43D34A41D7D0EBD30E9-8016
2 Faults Found:
01317 - Control Module in Instrument Cluster (J285)
Address 17: Instruments        Labels: 7L6-920-xxx-7L6.lbl
   Part No SW: 7L6 920 876 B    HW: 7L6 920 876 B
   Component: J285 KOMBI-INST.    9833
   Revision: KHH05V44
   Coding: 0007301
   Shop #: WSC 22526 001 1048576
   VCID: 3B2332A1AF609313469-806E
5 Faults Found:
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 152
                    Mileage: 188214 km
                    Time Indication: 0
                    Date: 2019.03.04
                    Time: 20:19:38
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 152
                    Mileage: 188214 km
                    Time Indication: 0
                    Date: 2019.03.04
                    Time: 20:19:38
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 152
                    Mileage: 188214 km
                    Time Indication: 0
                    Date: 2019.03.04
                    Time: 20:19:39
00470 - Company Comfort Databus in Single Wire
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01101011
                    Fault Priority: 2
                    Fault Frequency: 3
                    Reset counter: 154
                    Mileage: 188214 km
                    Time Indication: 0
                    Date: 2019.03.04
                    Time: 20:19:39
01300 - Control Module for Navigation with CD-Rom (J401)
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 41
                    Reset counter: 154
                    Mileage: 188214 km
                    Time Indication: 0
                    Date: 2019.03.04
                    Time: 20:21:46
Address 19: CAN Gateway        Labels:. 6N0-909-901-7L.clb
   Part No SW: 6N0 909 901     HW: 7L6 920 876 B
   Component: J533  GW-K-CAN TP20 9833
   Coding: 77E2EF9B6B066002
   VCID: 70B9D58DB6A6204BA3B-8024
6 Faults Found:
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 152
                    Mileage: 188214 km
                    Time Indication: 0
                    Date: 2019.03.04
                    Time: 20:19:38
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 152
                    Mileage: 188214 km
                    Time Indication: 0
                    Date: 2019.03.04
                    Time: 20:19:38
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 152
                    Mileage: 188214 km
                    Time Indication: 0
                    Date: 2019.03.04
                    Time: 20:19:39
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 3
                    Reset counter: 154
                    Mileage: 188214 km
                    Time Indication: 0
                    Date: 2019.03.04
                    Time: 20:19:39
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 41
                    Reset counter: 154
                    Mileage: 188214 km
                    Time Indication: 0
                    Date: 2019.03.04
                    Time: 20:21:46
02786 - Module 2 for Hatch / Trunk Lid (J756)
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 154
                    Mileage: 188374 km
                    Time Indication: 0
                    Date: 2019.03.14
                    Time: 00:00:02
Address 1C: Position Sensing        Labels: 7L6-919-879.lbl
   Part No SW: 7L6 919 879 B    HW: 7L6 919 879 B
   Component: Kompass         001 0001
   Revision: 00001000    Serial number: 1439802T14VG02
   Shop #: WSC 00000 000 00000
   VCID: 46D55355E4A2DEFB297-8012
2 Faults Found:
01299 - Diagnostic Interface for Data Bus (J533)
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 194
                    Mileage: 188374 km
                    Time Indication: 0
                    Date: 2019.03.14
                    Time: 14:01:14
00457 - Central Electronics Control Module / BCM (J519)
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 194
                    Mileage: 188374 km
                    Time Indication: 0
                    Date: 2019.03.14
                    Time: 14:01:14
Address 22: AWD        Labels: None
   Part No: 0AD 927 755 BG
   Component: TRANSFERCASE        0126
Address 36: Seat Mem. Drvr        Labels: None
   Part No: 7L0 959 760
   Component: Sitzverstellung     0702
   VCID: 77ABEE91D3D87773621-5184
1 Fault Found:
Address 37: Navigation
Cannot be reached
Address 46: Central Conv.        Labels: 7L0-959-933.lbl
   Part No: 7L6 959 933 A
   Component: 4M HSG              0601
   Coding: 0000085
   Shop #: WSC 06677 004 1048576
   VCID: 40D9454DC696F0CB13B-4B1E
   Subsystem 1 - Component:    TSG FT No Answer
   Subsystem 2 - Component:    TSG BT No Answer
   Subsystem 3 - Component:    TSG HL No Answer
   Subsystem 4 - Component:    TSG HR No Answer
7 Faults Found:
00668 - Supply Voltage Terminal 30
            002 - Lower Limit Exceeded - Intermittent
00576 - Terminal 15
01134 - Alarm Horn (H12)
            000 - - - Intermittent
            014 - Defective - Intermittent
00985 - Right Tail Light (M2)
01336 - Company Data Bus for Comfort System
Address 47: Sound System        Labels: 7Lx-035-4xx-47.lbl
   Part No SW: 7L6 035 456 B    HW: 7L6 035 456 B
   Component: 08K Audioverst.     0008
   Revision: 00006000    Serial number: 00000008153333
   VCID: 323D1F85782A525B95F-8066
1 Fault Found:
00421 - Rear Left DSP Midrange Speaker (R105)
            011 - Open Circuit - Intermittent
Address 55: Headlight Range        Labels: 7L6-907-357-A.lbl
   Part No SW: 7L6 907 357 C    HW: 7L6 907 357 C
   Component: AFS-Steuergeraet    0136
   Revision: 00H04000    Serial number:
   Coding: 1290371
   VCID: 3B2332A1AF209313469-806E
   Subsystem 1 - Part No: 7L6 941 329 B  Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul l    0004
   Coding: 00000019
   Subsystem 2 - Part No: 7L6 941 329 B  Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul r    0004
   Coding: 00000019
Address 56: Radio        Labels: 7L6-035-180-56.lbl
   Part No SW: 7L6 035 180 C    HW: 7L6 035 180 C
   Component: Radio DE2           0008
   Revision: 00006000    Serial number: VWZ4Z4J7302509
   Coding: 0001010
   VCID: 2D070CF961140DA3C8D-8078
1 Fault Found:
01044 - Control Module Incorrectly Coded
            000 - -
Address 68: Wiper Electr.        Labels: 7L0-955-119-V2.clb
   Part No: 7L6 955 119 B
   Component: J400__ Front Wiper  5301
   Coding: 0001397
   VCID: 392F28A9A55CA103545-806C
   Subsystem 2 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS     050209 054  0402
   Coding: 00208941
   Shop #: WSC 31414
Address 69: Trailer
Cannot be reached
Address 6D: Trunk Elect.
Cannot be reached
Address 6E: Ctrl Head Roof        Labels: None
   Part No SW: 7L6 919 044 AD    HW: 7L6 919 044 AD
   Component: J702  Dachdisplay   0401
   Revision: 1030006S    Serial number: 00000000108910
   VCID: 79AFE8A9E5DC6103145-802C
2 Faults Found:
             Freeze Frame:
                    Fault Priority: 7
                    Fault Frequency: 1
                    Reset counter: 194
                    Mileage: 188374 km
                    Time Indication: 0
                    Date: 2019.03.14
                    Time: 14:01:15
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 194
                    Mileage: 188374 km
                    Time Indication: 0
                    Date: 2019.03.14
                    Time: 14:01:16
Address 76: Park Assist        Labels: Redir Fail!
   Part No: 7L0 919 283 F
   Component: 0L Einparkhilfe     1108
   VCID: 392F28A9A51CA103545-806C
1 Fault Found:
End----------(Elapsed Time: 03:02, VBatt start/end: 14.5V/14.5V)-----------
Code:
www.Ross-Tech.com
69 6D 6E 76
Coding: 0004984
Revision: 00H53001
Coding: 0004354
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 9
Reset counter: 152
Mileage: 188251 km
Time Indication: 0
Date: 2019.03.12
Time: 01:49:57
Freeze Frame:
Count: 0
Count: 12289
Count: 156
Count: 1
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 22
Reset counter: 154
Mileage: 188374 km
Time Indication: 0
Date: 2019.03.13
Time: 00:00:46
Freeze Frame:
Count: 128
Count: 4353
Count: 294
Count: 1
Coding: 0000232
Component: ELV XXXX
4 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 14
Reset counter: 112
Time Indication: 0
Date: 2064.00.00
Time: 00:00:14
Freeze Frame:
Fault Priority: 6
Fault Frequency: 14
Reset counter: 112
Time Indication: 0
Date: 2064.00.00
Time: 00:00:14
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 149
Time Indication: 0
Date: 2064.00.00
Time: 00:00:14
Freeze Frame:
Fault Priority: 6
Fault Frequency: 0
Reset counter: 149
Time Indication: 0
Date: 2064.00.00
Time: 00:00:14
Coding: 0003030
1 Fault Found:
7 Faults Found:
Coding: 0000102
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 152
Mileage: 188214 km
Time Indication: 0
Date: 2019.03.04
Time: 20:19:49
Coding: 0013142
Coding: 0010211
2 Faults Found:
Revision: KHH05V44
Coding: 0007301
5 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 152
Mileage: 188214 km
Time Indication: 0
Date: 2019.03.04
Time: 20:19:38
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 152
Mileage: 188214 km
Time Indication: 0
Date: 2019.03.04
Time: 20:19:38
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 152
Mileage: 188214 km
Time Indication: 0
Date: 2019.03.04
Time: 20:19:39
011 - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 154
Mileage: 188214 km
Time Indication: 0
Date: 2019.03.04
Time: 20:19:39
Freeze Frame:
Fault Priority: 6
Fault Frequency: 41
Reset counter: 154
Mileage: 188214 km
Time Indication: 0
Date: 2019.03.04
Time: 20:21:46
6 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 152
Mileage: 188214 km
Time Indication: 0
Date: 2019.03.04
Time: 20:19:38
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 152
Mileage: 188214 km
Time Indication: 0
Date: 2019.03.04
Time: 20:19:38
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 152
Mileage: 188214 km
Time Indication: 0
Date: 2019.03.04
Time: 20:19:39
011 - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 154
Mileage: 188214 km
Time Indication: 0
Date: 2019.03.04
Time: 20:19:39
Freeze Frame:
Fault Priority: 6
Fault Frequency: 41
Reset counter: 154
Mileage: 188214 km
Time Indication: 0
Date: 2019.03.04
Time: 20:21:46
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 154
Mileage: 188374 km
Time Indication: 0
Date: 2019.03.14
Time: 00:00:02
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 194
Mileage: 188374 km
Time Indication: 0
Date: 2019.03.14
Time: 14:01:14
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 194
Mileage: 188374 km
Time Indication: 0
Date: 2019.03.14
Time: 14:01:14
1 Fault Found:
Cannot be reached
Coding: 0000085
7 Faults Found:
00576 - Terminal 15
1 Fault Found:
Coding: 1290371
Coding: 00000019
Coding: 00000019
Coding: 0001010
1 Fault Found:
000 - -
Coding: 0001397
Coding: 00208941
Shop #: WSC 31414
Address 69: Trailer
Cannot be reached
Cannot be reached
2 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 194
Mileage: 188374 km
Time Indication: 0
Date: 2019.03.14
Time: 14:01:15
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 194
Mileage: 188374 km
Time Indication: 0
Date: 2019.03.14
Time: 14:01:16
1 Fault Found:
Clear all faults and scan again.
Ok, here's the scan after clearing all DTCs.
Code:
Tuesday,02,June,2020,17:30:22:21308
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64(VirtualBox)
VCDS Version 20.4.1.0 (x64)  HEX-V2 CB: 0.4508.4
www.Ross-Tech.com
Mileage: 188370km-117047mi   Repair Order: 530
          69 6D 6E 76
1C-Position Sensing -- Status: OK 0000
47-Sound System -- Status: OK 0000
6E-Ctrl Head Roof -- Status: OK 0000
   VCID: 3C2131BDAA7E942B4F3-5185
   Coding: 0004984
   VCID: 015F80498D1C39C35C5-5185
   Revision: 00H53001
   Coding: 0004354
   VCID: 46D55355E4E2DEFB297-8013
2 Faults Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 9
                    Reset counter: 152
                    Mileage: 188251 km
                    Time Indication: 0
                    Date: 2019.03.12
                    Time: 01:49:57
             Freeze Frame:
                    Count: 0
                    Count: 12289
                    Count: 156
                    Count: 1
            000 - -
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 28
                    Reset counter: 154
                    Mileage: 188374 km
                    Time Indication: 0
                    Date: 2019.03.13
                    Time: 00:00:46
             Freeze Frame:
                    Count: 128
                    Count: 4353
                    Count: 294
                    Count: 1
   Coding: 0000232
   VCID: 313F10897D6C6943EC5-8065
   Component: ELV                 XXXX
4 Faults Found:
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 14
                    Reset counter: 114
                    Time Indication: 0
                    Date: 2064.00.00
                    Time: 00:00:14
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 14
                    Reset counter: 114
                    Time Indication: 0
                    Date: 2064.00.00
                    Time: 00:00:14
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 149
                    Time Indication: 0
                    Date: 2064.00.00
                    Time: 00:00:14
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 0
                    Reset counter: 149
                    Time Indication: 0
                    Date: 2064.00.00
                    Time: 00:00:14
   Coding: 0003030
   VCID: 79AFE8A9E59C6103145-802D
1 Fault Found:
   VCID: 0059854D864630CB53B-8055
7 Faults Found:
   Coding: 0000102
   VCID: 33331A8187305B539E9-8067
1 Fault Found:
            000 - -
             Freeze Frame:
                    Fault Priority: 7
                    Fault Frequency: 1
                    Reset counter: 154
                    Mileage: 188374 km
                    Time Indication: 0
                    Date: 2019.03.23
                    Time: 03:36:37
   Coding: 0013142
   VCID: 7AADF7A5E09A6A1B1DF-802F
   Coding: 0010211
   VCID: 43D34A41D7D0EBD30E9-8017
2 Faults Found:
   Revision: KHH05V44
   Coding: 0007301
   VCID: 3B2332A1AF609313469-806F
5 Faults Found:
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 154
                    Mileage: 188374 km
                    Time Indication: 0
                    Date: 2019.03.23
                    Time: 03:36:27
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 154
                    Mileage: 188374 km
                    Time Indication: 0
                    Date: 2019.03.23
                    Time: 03:36:27
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 154
                    Mileage: 188374 km
                    Time Indication: 0
                    Date: 2019.03.23
                    Time: 03:36:28
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 154
                    Mileage: 188374 km
                    Time Indication: 0
                    Date: 2019.03.23
                    Time: 03:36:28
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 154
                    Mileage: 188374 km
                    Time Indication: 0
                    Date: 2019.03.23
                    Time: 03:36:28
   VCID: 70B9D58DB6A6204BA3B-8025
6 Faults Found:
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 154
                    Mileage: 188374 km
                    Time Indication: 0
                    Date: 2019.03.23
                    Time: 03:36:27
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 154
                    Mileage: 188374 km
                    Time Indication: 0
                    Date: 2019.03.23
                    Time: 03:36:27
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 154
                    Mileage: 188374 km
                    Time Indication: 0
                    Date: 2019.03.23
                    Time: 03:36:27
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 154
                    Mileage: 188374 km
                    Time Indication: 0
                    Date: 2019.03.23
                    Time: 03:36:28
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 154
                    Mileage: 188374 km
                    Time Indication: 0
                    Date: 2019.03.23
                    Time: 03:36:28
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 154
                    Mileage: 188374 km
                    Time Indication: 0
                    Date: 2019.03.23
                    Time: 03:36:28
   VCID: 46D55355E4A2DEFB297-8013
   VCID: 77ABEE91D3D87773621-5185
1 Fault Found:
Cannot be reached
   Coding: 0000085
   VCID: 40D9454DC696F0CB13B-4B1F
7 Faults Found:
00576 - Terminal 15
   VCID: 323D1F85782A525B95F-8067
   Coding: 1290371
   VCID: 3B2332A1AF209313469-806F
   Coding: 00000019
   Coding: 00000019
   Coding: 0001010
   VCID: 2D070CF961140DA3C8D-8079
1 Fault Found:
            000 - -
   Coding: 0001397
   VCID: 392F28A9A55CA103545-806D
   Coding: 00208941
   Shop #: WSC 31414
Address 69: Trailer
Cannot be reached
Cannot be reached
   VCID: 79AFE8A9E5DC6103145-802D
   VCID: 392F28A9A51CA103545-806D
1 Fault Found:
End----------(Elapsed Time: 03:00, VBatt start/end: 14.6V/14.7V)-----------
Does the Treg start?
You have some serious wiring issues there.
Is your battery good and tested?
Discussion Starter #8
Yes the car runs fine and things like the central locking/windows from inside the car work fine apart from the rear passenger door window. All internal and external lights are working, HVAC, sunroof, radio. I am unable to unlock the car using the keyfob, the tailgate and rear window won't open, the rear wiper won't turn on.
Discussion Starter #9
Oh forgot to mention, it has a new battery that was put in before I acquired the car and voltage checks out fine.
I wouldn’t drive it in that shape with all those errors. Do you have an aftermarket radio?
Ah I don’t know what that is. Can you disconnect it and clear codes and scan again?
If you have a battery charger you better use it when scanning.
Discussion Starter #13
After some troubleshooting and help from the ross-tech forums, I managed to find these corroded wires at the base of the passenger side b-pillar. Will be putting it back together today and running some more scans. Hopefully that solves my problems. I'll report back.
237662
Something like this?
1 - 14 of 14 Posts
