1 - 3 of 3 Posts
Right, so I got in my '05 Touareg last night to go to the corner market. When I turned the ignition, the lights came on, then went out, all in about 1 second. Once the vehicle started, I turned the light switch to the 'on' position, and nothing.
Fuse? Bulbs burnt out simultaneously? I would first check your headlight fuses, then the bulbs. If those are all okay, perhaps it is the switch itself.
Thanks Scubacruiser, I'm thinking the same thing. I tested the high beams earlier and they work fine.
1 - 3 of 3 Posts
